What color is the amp turn-on wire for non-Bose for 2k2?
Old Jul 29, 2002 | 10:15 AM
nismomax's Avatar
I'm trying to hook up an amp to the factory nonBose unit and having problems. I'm using a line level converter and am sure that I've got the speaker wire tapped correctly. So it has to be the amp tunr on wire that I may have misconnect. Help
Old Jul 29, 2002 | 10:23 AM
remykins's Avatar
Re: What color is the amp turn-on wire for non-Bose for 2k2?
The non Bose head unit doesnt have an amp lead. If I remember correctly you just have to supply power to the line converter by tapping the speaker. Since there is no amp lead I think you have to run a wire to the switched power in the car. Someone please correct me if I am wrong as it has been a few years since I have done this.
Old Jul 29, 2002 | 10:38 AM
y2KAOSMax's Avatar
Remykins is right there is no rem wire. You can use the front lighter power wire, that's what I used.. Or some have ran a wire to the radio fuse in the fuse box, which I will try to do when I get around to it...
popdedop
Sep 11, 2015 11:17 AM
