H&R's Installed wicked vibration when accelerating
Old Jul 30, 2002 | 05:55 AM
CJLax's Avatar
Hey I finally got those H&R's installed from the Avalon GD. Drove the car out of the shop however I drove home thru back roads not exceeding 40mph. The car felt fine looks great. This morning on my way to work on the highway I noticed that the car was vibrating alot during exceleration. I won't be able to bring it back to the shop til Fri. any hints as to this problem? Will I seriously damage the car if I continue to drive it? The car coasts fine only during speed up. Some say that you need an alignment after springs seatle, others have no problem whatsoever. I'm worried that if I bring the car to the dealer he my void warranty due to all the mods. Any insight on this matter would be greatly appreciated. Also I'll do a search on this when I have the time. Thanks
Old Jul 30, 2002 | 08:01 AM
soundmike's Avatar
Very sound, Mike
Sound like an alignment issue to me. I know you said some people didn't need it while others did. It's all about how the installers did their job.
Old Jul 30, 2002 | 08:15 AM
dblrr900's Avatar
Every shop I have talked to before says you need an alignment when you lower a car. Go to the shop my man. Get that thing aligned.
Old Jul 30, 2002 | 08:46 AM
Jeff K's Avatar
Try the basics first...>
Try the simple things first before thinking worst case. Make sure you wheel lugs are tight. If the wheel lugs are fine then open the hood and make sure the nuts on the shock tower nuts are tight. There is a nut in the center of the shock tower nuts that also should be very tight. If any of these items are hand tightened and not torqued properly it will cause noise and vibration.
Old Aug 1, 2002 | 05:39 AM
CJLax's Avatar
Vibration during excelaration
Well I just found out what caused this vibration when I was excelerating. Turns out that the people who installed my springs did not put my axle back on properly. It ruined the drive shaft which now needs to be replaced at a cost of over $400. They said I was lucky it didn't fall off while I was driving. $100 install $400 fix. I wish these guys would check their work more thoughly, this could have been a major mishap. Lets see if they honor the fix. Just so happens the car died in front of a Mitsubishi dealer; a friend of mine is the GM their.
Old Aug 1, 2002 | 05:53 AM
perrymaxima's Avatar
CJ regardless of the Drive axel problem.
Get the car aligned to prevent tire wear caused by lowering the car. I have heard of others on the board that waited too late and because of the severe tire wear had to buy new tires.
No need to cause even more problems on top of the whole drive axel replacement. Lower the car properly the first time to prevent heard aches later.
Who lowered your car by the way so that others won't get screwed?
Old Aug 1, 2002 | 07:00 AM
ru4real's Avatar
Re: Vibration during excelaration
What do you mean, they didn't put the axle back on properly? Why would they have to do remove the axle for the spring install?
Have you told the installers they screwed up? Do they have any kind of warranty?
Old Aug 1, 2002 | 12:04 PM
CJLax's Avatar
Re: Re: Vibration during excelaration
I'm in the process of working out this issue with them as we speak. They have to tow it back to there shop and see what the damage is. It's 3pm and so far no word. Another day without my ride.
Old Aug 1, 2002 | 12:44 PM
srbarnes4ever's Avatar
Huh? You lost me somewhere because there is absolutely NO axle or drive shaft involvement in a spring/strut change. How did they ruin it...something sounds fishy...you might want to keep an eye on the car while a reputable mechanic gives it the once over. I'm assuming there was NO vibration before the install so something must have been done wrong, I'm just not understanding how the axle was involved. Good luck either way!
Old Aug 2, 2002 | 08:50 AM
CJLax's Avatar
I hear you, I thought the same thing from reading everyones post. No invovlement with axle, however when the mechanic put it on the lift there it was axle loose as hell. I have no idea what they did but it seems like there taking care of it now. When I drive the car and everything is ok with no permanent damge I'll be happy. My first new car and all you org members and your suggestions in how to mod this car is great. I just hit my first major snag with this mod I hope that it does'nt sour me from doing more. I'll post when I get it back complete and with no vibration.
Old Aug 7, 2002 | 04:55 PM
CJLax's Avatar
Bad news, Install screw-up
Well guys here it is. I was told that the place who did the install was at fault. First off The right side axle went bad, then the left side cv boot was ripped. I my be explaining this wrong due to the fact that I'm beyond ****ed. I told the shop that it was their doing and they told me that they were not familiar with H&R's and that I didn't purchase the springs from them so therefore there not lible. Yea right; $1500 damage later. Speed shop my a#%%. I had to cash in on a few favors from a couple of car dealer friends. Axle covered thru warranty, CV boot not, $240 out of pocket not bad. It still su%ks
but I consider myself lucky. I do a lot of highway driving lucky car didn't fail on the way to work. Still waiting for parts from dealer. I drove in with all my mods and nothing said about them, only that I'm lucky to have a friend in the business. Without my ride for a week now. Let you know what happens when car rolls out of dealer. I'm afraid they will tell me not to bring the car back like that again. W'ell see.
Old Aug 7, 2002 | 05:29 PM
00Semaxi's Avatar
was this the front axle or rear axle, because i had my maxspeeds installed about 2 months ago and when im accelerating hard, it feels like the rear is i hear a bouncing type noise coming from the rear, almost like a rattling.
Old Aug 7, 2002 | 07:30 PM
Newman's Avatar
maybe the shop loosened a bolt holding the axle in place thinking it was a bolt for the suspension
i still think they should be held liable. even if they are no familiar with it, they willingly took the job. try to get them to pay for the $240 CV boot.
Old Aug 7, 2002 | 08:43 PM
K Pazzo 6's Avatar
first off...post the name of this shop so nobody goes there....
second off-- i hope u have a receipt for the job they did, if so go pay an attorney to write that shop a letter to pay it otherwise court action will be looked that....most the time that scares 'em
Old Aug 7, 2002 | 09:06 PM
NickStam's Avatar
take them to court. they don't know how to install springs and are blaming you? ha!
Old Aug 10, 2002 | 08:17 AM
CJLax's Avatar
Dealer saves the Day.
Well finaly, I got my car back in one piece from the dealer. H&R's are still on with all the mods included, nothing said. I also noticed some other Maxs there with mods, so no problem as far as mods are concerned at this dealer. Freehold Nissan did a great job with the repairs. New axle covered under waranty, CV boot not. The guy at the speed shop paid for the cost of the boot and my car rental for the week. After declining to take responsibility, I guess $400 dollars was better than $1500. A lessoned learned here; I took it for granted that it was an easy install due to the fact that many people do the install right in there driveways. I assumed that it would be an easy job especially for a "SPEED SHOP". I learned to ask specific questions and not assume. Disaster averted due to a few connections. I don't want to rip this guy on a public forum however when I walked in today he took out his check book no questions asked and gave me a check. If you guys want to know PM me and I will give you the shop name. It's in Englishtown NJ, near the Track off of RT 527. The guy was straight forward somewhat. The car handles great but not like stock like everyone states. The car is somewhat smooth like stock but very bumpy and low to the ground. You can feel every bump now. Not bad though, this is the price you pay for performance and style. When the new shocks come out next year I will upgrade and see if this helps smooth out those bumps. If not I'll get used to the new feel.
MaxLife17
Jun 27, 2019 01:37 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
jcvgn
Sep 10, 2015 08:03 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
Johnny9595
Sep 3, 2015 05:18 AM
