What color red 4 taillights?
Old Aug 5, 2002 | 07:30 PM
max34's Avatar
I want to paint the clear "turn signal" section red, and I forget what color red was used.
Red, Bright Red, or Candy Apple Red??? All are Testors model paint.
Old Aug 5, 2002 | 09:26 PM
Y2KSESteve's Avatar
why?
Old Aug 5, 2002 | 11:18 PM
2M0A0X2's Avatar
pm emax95
Old Aug 6, 2002 | 05:25 AM
max34's Avatar
Originally posted by Y2KSESteve
why?
To get rid of the white in the brake circle.
This way you'll have one large red circle and one small white circle.
Old Aug 6, 2002 | 12:57 PM
Y2KSESteve's Avatar
So you want a red turn signal? That's not a bad idea. Post pics when you're done, unless someone else has any. thx
Old Aug 6, 2002 | 02:05 PM
max34's Avatar
EXACTLY...now what color?
Old Aug 6, 2002 | 02:18 PM
jjs's Avatar
jjs
not sure if this is intended...
but would not any paint be opaque and thus render the turn signal non-functional?
In order to have this work, a transparent or translucent application should be used...
Old Aug 6, 2002 | 02:31 PM
Y2KSESteve's Avatar
Re: not sure if this is intended...
huh? Sorry d00d, but ya lost me.
Old Aug 6, 2002 | 02:51 PM
8702's Avatar
Re: Re: not sure if this is intended...
Painting over the light would render the light useless. Light wouldn't be able to pass through the paint. You need some kind of transparent/clear paint.
Old Aug 7, 2002 | 05:26 AM
max34's Avatar
Negative!!
When you put one coat of Testors paint on, there is no way to make it opaque. Especially when you're back-lighting it with a bright turn signal. I'm painting over a clear lense, a friend of mine painted over an amber section of his taillight, and it still worked just fine. SOMEBODY ON THIS BOARD HAS DONE THIS!! I just can't remember who.
Old Aug 7, 2002 | 05:47 AM
mingo's Avatar
when i had my crx i painted the oranged red using remote control car lexan body spray paint. i believe the color was called candy apple red (or something) if i can recall it was translucent. spray that on in thin coats, and then add a clear coat for a glossy finish. if you get teh orange peel effect don't worry about it, spray even more coats of the clear coat on, get some very very fine grade sand paper for polisihing, and wet sand it..
Old Aug 7, 2002 | 05:54 AM
max34's Avatar
Mingo...love that strut bar! You need to get into the import business and bring those over here.
Old Aug 7, 2002 | 05:59 PM
mingo's Avatar
thot about it.. but i'm too lazy.
Old Aug 7, 2002 | 07:32 PM
radpp16's Avatar
Re: Negative!!
Yo_its_ok did it, i believe he used candy apple, dont know almost 3 years now.
Roger
doctorpullit
Oct 28, 2019 10:58 PM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
bigfrank
Oct 1, 2015 12:51 PM
