Please? Someone with 2000-2001 SE Manual Tranny AND stock suspension......
Old Aug 6, 2002 | 09:32 AM
asu174's Avatar
Clay Aiken has fancy genitals
Could you please measure the distance between the ground and the wheel well for front and rear? Please measure at the center of each wheel.
I am trying to figure out how much of a drop I currently have.
Thanks! I really appreciate it!
Old Aug 6, 2002 | 10:15 AM
Sly's Avatar
Sly
Unfortunately, I can't help you right now but if someone has access to the ESM, it's in there. I think in the suspension section, it has a table for front and rear wheel well heights, listed by what wheel you have (15", 16", 17").
Old Aug 6, 2002 | 10:36 AM
dave's Avatar
Re: Please? Someone with 2000-2001 SE Manual Tranny AND stock suspension......
2000 SE Manual stock suspension (stock tires, stock rims)... that's me. i'll measure tonight, and post if noone else beats me to it - or if i'm bored at work, i'll take a walk out to the car.
Old Aug 6, 2002 | 10:46 AM
Green 2kSE's Avatar
I don't know if this is what you need, but I measured the distance from the top of the wheel arch of the fender to the floor and it came to 27.5" for front and 27" for rear. The car has a full tank of gas if that makes a difference.
Old Aug 6, 2002 | 10:51 AM
dave's Avatar
all work and no play makes dave a dull boy...
car was on lumpy asphalt and not level, so the best i could measure was:
front 27.75" (stock tires, rims, 33PSI)
rear 27.25" (stock tires, rims, 31PSI)
hope that helps.
Old Aug 6, 2002 | 11:01 AM
asu174's Avatar
That helps A LOT! Thanks a million!
Old Aug 6, 2002 | 11:05 AM
asu174's Avatar
The consensus seems to be that there is a .5 inch difference between the front and the rear. That is what I was looking for...
Old Aug 6, 2002 | 04:07 PM
Sly's Avatar
Sly
From the good book....
Wheel arch height from ground (Front/Rear) in inches
Models with 225/50R17 tire: 27.80/27.32
Models with 215/55R16 tire: 27.48/26.89
Models with 205/65R15 tire: 27.56/27.17
Fuel, radiator coolant and engine oil full. Spare tire, jack, hand tools and mats in designated positions.
Old Aug 7, 2002 | 04:51 AM
Norm Peterson's Avatar
Tire pressure appears to affect this slightly. I measured 27-3/4" front and just under 27" rear with 35-ish front and 29-ish rear cold pressures. That's with about 3/4 tank of gas and maybe 15 lbs of miscellaneous stuff in the trunk. I'm guessing that tire wear is about 1/8".
Norm
9aj9
Apr 5, 2020 12:11 AM
pktaske
May 6, 2016 07:49 AM
iamute
Sep 20, 2015 05:22 PM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
