My new wheels RUB!!! GRRRRRRRR!!!!!!
Old Aug 10, 2002 | 03:41 AM
cobymoby's Avatar
Well, I was all happy because I just got me new wheels, everything was great until I started taking some hard turns and went over speed bumps. The rear definately rubs! I had two not so heavy people in the back and going over a bump in the road makes them rub. It's hitting the inside splash gaurds. It's not rubbing a lot, but when I hit a bump, the sound reverberates through the car VERY loudly.
Now I have to raise the rear.
This is my setup as far as my suspension goes:
JIC FLT-A2 Coilovers
Addco rear sway
18x8.5 SSR GP-Theta 3pc w/ +37 offset
245/40/18 Nitto NT-555
Now, my question is, why doesn't Kloogy, Gunmax, or Y2KevSE's 8.5's rub? I have roughly the same offset as them. 35, ??, 38 respectively.
Old Aug 10, 2002 | 03:43 AM
cobymoby's Avatar
But one thing that I am happy about......
It handles AWESOME!!! Now I fully realize how bad those Blowtenzas are! Those tires are garbage!!
Old Aug 10, 2002 | 04:00 AM
asu174's Avatar
Clay Aiken has fancy genitals
Someone's an insomniac just like me.
Do you have a pic of the wheel? I can't find it anywhere online.
Old Aug 10, 2002 | 04:24 AM
cobymoby's Avatar
My digi cam is down. I'll get them up soon. PS- I'll send your stuff out tomorrow.
Old Aug 10, 2002 | 04:27 AM
asu174's Avatar
Thanks again bro......
Old Aug 10, 2002 | 08:14 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Yes, I rub a bit when I turn the wheel fully to the left.
Reason why: I'm too low and my SC CAI causes the right plastic fender to bulge out a little.
Raise your car up about 2 notches, and you should be fine.
Old Aug 10, 2002 | 08:35 AM
asu174's Avatar
Kev- I didn't know you had the GC's. I thought I was the only one. Question- Why is it banging REALLY loud over bumps when I drop my car down? I know that I'm not bottoming out. It's coming from the wheel well.
Here's my setup:
GC's
KYB AGX's
Stillen camber kit
I took it to a suspension shop and they said that everything looked fine. The weird thing is that the problem started ONLY after I got the KYBs on.......
Old Aug 10, 2002 | 08:38 AM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
have you considered modifying the splash guard so that it fits better.
how low is your front, my rears are tucked and they are only 7.5 wide so luckily i've never had any rubbing, but my tires are 245/40/18. i just wish my front was a little lower so it looked more even but unless i get coilovers that woin't happen with any springs out for a maxima. they are something i'd consider way after i was done with a lot of other things for my car, i really want AWESOME speakers now.
Old Aug 10, 2002 | 11:04 AM
Y2KevSE's Avatar
Here's my setup:
GC's
KYB AGX's
Stillen camber kit
Is the front or the rear banging? What are your settings on the AGXs?
Old Aug 10, 2002 | 12:03 PM
asu174's Avatar
Front is banging. Loud. Especially while turning and going over bumps. Front setting is on 2 although it bangs on 4 also. I'm starting to think that KYBs are crap.
Old Aug 10, 2002 | 02:50 PM
cobymoby's Avatar
I found out where it's rubbing.
I need to shave the inside of the fender 1mm, literally, 1mm!! When the suspension compresses, the sidewall of the tire is JUST grazing the fender. Out comes the dremel.....
Old Aug 11, 2002 | 08:57 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Dremel
Are you still loving the JICs? I'm so set on them, but I'm still trying to save up. BTW, did you ever measure your drop or see how low they can be adjusted?
Old Aug 11, 2002 | 09:14 PM
Modernceo's Avatar
Hrrm.. makes me scared of my new wheels. Mine are 18' Racing Hart C3's with 42mm offset.. I was already freaking out about wether or not they would fit, then I read this thread
Old Aug 11, 2002 | 09:48 PM
cobymoby's Avatar
Those will fit for sure. If I had 1-1.5mm of more clearance on the fender it would not rub at all. You, with a 7.5" rim, and a 42mm offset, you have 12.7mm+5mm=17.5mm of clearance.
Did you already buy your C3's? IF not let me know.
Old Aug 11, 2002 | 10:11 PM
KLOOGY's Avatar
L33t BMW Drivah
I have the 35 offset with 245/35's... I'm sure your Coilovers make your car lower. I have only done real hard cornering with 2 people in the car. I have done a bit of driving with 4 people in the car, a lot of it even in Baja Calif... no rubbing yet.
Old Aug 11, 2002 | 11:21 PM
Modernceo's Avatar
Yes I already bought the C3's. I presume your going to offer to help me get a set, however I run a tuning shop in Houston Texas and have pretty good connections for just about any part I want.
Thanks for your offer though, and for your reply to my post.
Ps- how do you like your rear sway bar ? Are the brackets already there for connecting the rsb, or whats involved in getting it installed? (have had my max for less than two weeks, havent had a chance to fully inspect underside yet)
Old Aug 12, 2002 | 02:06 AM
cobymoby's Avatar
The sway is great. I wished I had gotten one sooner. The brackets just hug the rear axle and trailing arms. It's a simple install. On the passenger side bracket that hugs the axle, you might want to shave the corner off with a hacksaw or bench grider. When you install it, you'll see where it may hit. It's soft metal so it won't take much time.
Old Aug 12, 2002 | 02:09 AM
cobymoby's Avatar
It's actually rubbing the sidewall of the tire as the suspension compresses. The fender is rubbing (metal), not the inner splash gaurd. There is about 1/2 a finger gap in the front, a little less in the rear.
Old Aug 12, 2002 | 02:10 AM
cobymoby's Avatar
What kind of wheels did you get?
Old Aug 12, 2002 | 07:50 AM
5-Zigen MO-5 Inperios in 18x7.5 not sure of the offest but i could look.
I know 245 on a 7.5 is pushing it but i went to one of the best shops in the area and they mounted them for me no scratches. i like the bulge you get with that wide a tire on that rim. it's gonna be hard to curb rash them plus you get that extra contact patch.
Old Aug 12, 2002 | 12:48 PM
irvine78's Avatar
although i don't have 8.5s...mine are 19x8s...245/35/19s...i only rub if i have a passenger in the back, or drive real fast on one of those freeway bumps...
Old Aug 12, 2002 | 01:02 PM
Y2KevSE's Avatar
Does it sound like springs popping? *BOING* ?
Old Aug 12, 2002 | 10:21 PM
KLOOGY's Avatar
L33t BMW Drivah
Can someone tell me why Im not rubbbing ? Are Maxspeeds the reason, or any other item ?? I only had them rub once in Mexico with 4 people in the car over a heavy dip.....
Old Aug 13, 2002 | 01:00 AM
cobymoby's Avatar
That's what I want to know!! We have the same width tires (245) and wheels 8.5. Kloogy has a +35 so he has even less clearance than me (I'm a +37). I rolled my rear fenders TWICE today and it still rubs, although not as bad.
My suspension in the rear is lowered so that I can just fit my finger between the top of the tire and fender. The front fender gap is a bit tighter than that.
Old Aug 13, 2002 | 08:27 AM
HulaMAX's Avatar
So would it be safe to say 19x8.5's w/ 40 offset wrapped in 245/40's won't rub???
Old Aug 13, 2002 | 09:18 AM
Madd Kidd's Avatar
What are you guys refering to when you mention the offset of your wheels? Sorry for the ignorance.
Old Aug 13, 2002 | 09:59 AM
madmax2k's Avatar
Instead of the dremel, try a wooden baseball bat. Sometimes, you can roll the inside of the fender lip with the bat enough to clear the offending tire. Put one side of the bat on the top of the tire and have the handle end sticking out (towards you if you are standing looking at the tire). Then, gently "roll" the bat along the top of the tire while pushing down on it (so the bat wants to rub up against the inside of the wheel well.)
If you only need 1mm, Id give this a try. If you are careful, you can do it without cracking the paint on the inside of the lip. (The dremel will obviously remove the paint, which can lead to corrosion down the road.)
Old Aug 13, 2002 | 05:18 PM
MAXRAY's Avatar
i'm not 100%, but i believe MM evo5's in 19's have 40mm offset. i called tirerack the other day and that's what they told me.
Old Aug 13, 2002 | 08:56 PM
cobymoby's Avatar
I looked at the sheetmetal and said forget it with the deremel. I used the baseball bat method to roll my fenders. Good thing I had practice on other people's cars before I did it to my own car.
Old Aug 13, 2002 | 11:15 PM
KLOOGY's Avatar
L33t BMW Drivah
Thats who my wheels came from. I called the guy who ordered them for me, and he told me they were 35 offset. He might have been wrong...??
Old Aug 14, 2002 | 03:33 AM
Gunner's Avatar
i heard others recommend 245/35r19's for our cars. ????
Old Aug 14, 2002 | 07:25 AM
HulaMAX's Avatar
I heard/read those fit better too, but I want to go with a larger series tire to hopefully prevent any damage from potholes or dips...cuz there are plenty in SoCal.
Fbana41
Aug 29, 2016 12:18 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Andy29
Sep 29, 2015 05:32 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Redfox
Sep 28, 2015 10:41 AM
