I NEED URGENT HELP~!!!! hello
Old Aug 11, 2002 | 02:40 PM
redfly17's Avatar
i accidentally locked my keys in the trunk of my car... i managed to pry open the door and fit a coat hangar to press the unlock button. but when i opened the doors the alarm went off and that must off cut the power to the trunk release. now i am sitting in the middle of my street with my car's battery unplugged and my rear seats partially disassembled.. i have a question for u guys... will any 5th gen maxima's key work in the fold away rear seat lock hole??? if i get that unlocked i can just reach in and get my keys... anyone in boston please help!!
Old Aug 11, 2002 | 02:56 PM
redfly17's Avatar
does neone have a diagram to take apart rear seats?! i have bottom half out, the backs are much harder... plz help
Old Aug 11, 2002 | 03:02 PM
K Pazzo 6's Avatar
try connecting your battery again & if alarm doesnt go off then pull the trunk release....
Old Aug 11, 2002 | 03:03 PM
Green 2kSE's Avatar
How do you end up in the middle of your street with your keys in the trunk and keep posting at the same time?
Old Aug 11, 2002 | 03:08 PM
2001SilverSeMax's Avatar
Even if the alarm does go off, just pull the trunk release and then disconnect the battery until you get your remote out of the trunk. Then reconnect the battery, and press the unlock button on the remote. I don't see why this wouldn't work.
Old Aug 11, 2002 | 03:09 PM
redfly17's Avatar
how bout going to a nissan dealership and asking them for a new keyfob? does he need to be at my car to program it? how does that work?? man i just need my trunk open!!
or how bout sending an 9V electrical current through the fuse of the trunk release... will that work?!?! HELP!
Old Aug 11, 2002 | 03:10 PM
redfly17's Avatar
GUYS THE ALARM STAYS ON AFTER I RECONNECT THE BATTERY! AND IT STILL WOULDNT LET ME OPEN THE TRUNK! for sum reason the fuel door opens up tho
Old Aug 11, 2002 | 05:17 PM
emax02's Avatar
You've got your self in a pickle . I don't think you can un-bolt your rear seat if it's locked in place. Why do you have locked anyhow I forgot you could even lock it.
FYI if you give your nissan dealer your vin # they can cut you a new key for your car. With that you should be able ot open your trunk. Have fun and good luck.
Old Aug 11, 2002 | 06:03 PM
MaxAtack's Avatar
That's ALOTTA running around to do!
Old Aug 11, 2002 | 06:29 PM
ThurzNite's Avatar
this's a stretch. take apart the dash area by the steering column. Then find the wire that disarms the stock alarm. Zap it with 12v (or 14...not sure which) and that should turn it off.
I'll do my best to obtain a service manual and find out which wire it is.
Jae
Old Aug 11, 2002 | 08:35 PM
Max_5gen's Avatar
Jae
I don't think there is such a wire and you actually can damage car's electrical system trying to zap something to 12V. I'd recommend to open window with battery connected if this is possible. Then disconnect battery, find alarm hood switch - the thing with wires and rubbered end which gets pressed with hood closed. Press it with something imitating closed hood, close all the doors and connect battery. Then sneak in through driver's open window and pull trunk release. I think, your opened hood sets off alarm again when you reconnect battery. This MIGHT WORK, I'm not 100% sure. I haven't seen 2k2 elecrical diagram yet. For 2k guys it wouldn't be a problem at all - we can pull that release button at any time no matter what alarm thinks about it. Is this good or bad I don't know. 2k1 guys probably have it disabled the same way you describe.
Mike.
Old Aug 12, 2002 | 12:17 AM
redfly17's Avatar
problem solved
its ok guys. i found the least expensive most time consuming way to fix this problem. i drove 400 miles in a friends car to get my spare keys and just got back. man i will never do that again.
Old Aug 12, 2002 | 12:20 AM
redfly17's Avatar
i musta made 600 dollars worth of damages and paint scratches to the door of the car. i really scratched it up pretty bad with the flat head screwdriver. im just glad its on the inner panel where no one can see. i will touch it up tomorrow morning.
Old Aug 12, 2002 | 07:31 AM
Young04's Avatar
Re: problem solved
we must seriously LOVE our maximas. the moment they're in trouble, we will put down everything until the problem is fixed. i'm definitely not criticizing because i'd do the same thing too. heheheh
Old Aug 12, 2002 | 07:55 AM
Igor911's Avatar
Re: Re: problem solved
I wanna know how he can post and be in the middle of the street at the same time?? Geee, now that is skills.
Old Aug 12, 2002 | 08:23 AM
serin's Avatar
dude, this problem is sucky.. but kinda funny at the same time.
teeezmaxSE
30
Aug 16, 2005 11:46 AM
PoePoe2797
Jun 18, 2004 06:31 AM
