Can the Brace under Y-Pipe Be removed?
I still get banging on my y-pipe to the brace everytime I hit hard on the gas. I did put washers on it and it helped until I swapped out my catback. Now it's hitting again. Can I just remove that bracket and then just srew in that ground wire. Is the bracket required???
Re: Can the Brace under Y-Pipe Be removed?
I can't see what purpose it serves either. It would only come in handy if the weld breaks on the B pipe.
i asked a local mechanic if it made a difference. he said that it didnt but if you asked the engineers who designed the car, they would say that it does. i just connected because it took 2 secs.
Originally posted by sleepermax
Well if you consider how sturdy the brace is and the fact that it's anchored by 8 fairly substantial bolts, it's pretty evident that the brace does have a structural function (chassis rigidity?). Otherwise Nissan would have made it somewhat similar to the much smaller brace (held by two bolts) further back under the B-pipe. There's no reason to have such a hefty brace if its' only purpose is to hold up the exhaust piping in case it somehow becomes unattached. In other words Nissan wouldn't spend the extra cash for this if it wasn't deemed necessary. I would just get longer bolts and more washers and keep the brace on.
Originally posted by emax95
Can you say weight reduction?
My braces and trailer hitches are comming off tomarrow, muhahaha!
It definitely ways a lil heavy.. But the structural integrity does make sense. But then again a lot of people have removed it with no problems???
My FSTB and RSB will take care of that problem.
I guess I can say the same.. fst, fstb, and rsb will make up for it too... I'm gonna take mines off tomorrow.. Lemme know if you feel any difference..
I removed the braces today and I feel a noticable difference. My steering response is now sloppy, it feels like my car did before my RSB. I'm going to look into the WSP subframe conectors now, stage 1 and 2. BTW there is no more nasty banging noises during hard launches and 1-2 shifts. The braces probably weigh about 3-4 lb's combined.
my03maxima
Jul 28, 2024 07:40 AM
RealityCheck
Oct 2, 2015 06:34 PM
