About That Sunroof Problem, Y2KSilvahSE....
Aug 17, 2002 | 09:31 AM
Ok, remember when i posted that unplugging the battery will not work? Well, I was wrong.
I have had the same problem ever since I bought the car. THe lady who had the car before me did too. I have the estimate in front of me. $298.00
I went out, disconnected my battery, stepped on the brake, connected the battery, and the ****** fu##er works.
I am happy because my sunroof works.
I am pis$ed because those a-holes were going to charge me $298.00 for a new sunroof motor.
Do they NOT know to disconnect the battery, or are they just crooks?
Aug 17, 2002 | 11:26 AM
Re: About That Sunroof Problem, Y2KSilvahSE....
Quote:
Originally posted by jjames
...Do they NOT know to disconnect the battery, or are they just crooks?
The folks at Ford has no idea how to fix my wifes Sunroof so they were ready to install a new one at THEIR cost....I then found the reset instructions after reading about them on the .org on the 2K2's.
I think these guys really dont "analyse" the problem. The "hear" they symptoms and then run through a check list. And if it doesnt throw a code...good luck!
Lets see what your long term results are of the battery disconnect....
Aug 17, 2002 | 11:36 AM
Re: Re: About That Sunroof Problem, Y2KSilvahSE....
True. However, I have a hard time believing that nobody in that service department knows about that fix.
It's like your computer. When you getr the B.S.O.D, you reboot. Same with the car. Sort of.
Aug 18, 2002 | 11:10 AM
Re: Re: Re: About That Sunroof Problem, Y2KSilvahSE....
Bump
Aug 19, 2002 | 06:12 AM
Re: Re: Re: Re: About That Sunroof Problem, Y2KSilvahSE....
Jjames...it worked??? you gutta be chittin me...I didnt try cuz it was the major consensus that it would be useless...
Whats up with hitting the brake? to discharge any capacitors holding juice in the electrical system? (I would think)...
Well chit, I definitely will be doing it asap dude...
Thanks alot for getting back with me man....
Aug 19, 2002 | 08:17 AM
Re: Re: Re: Re: Re: About That Sunroof Problem, Y2KSilvahSE....
Quote:
Yeah, I think so. I remeber reading that on .org once. It worked!!!
Aug 20, 2002 | 06:42 AM
There is no telling how many sunroof motors Nissan has replaced that had nothing wrong with them. I have seen a lot of people post this problem with their sunroof..and when you consider that only about 1% (or less) of Maxima owners EVER come to this site....then there is no telling how many people are actually having this problem.
Aug 20, 2002 | 06:47 AM
Yea, seems like Nissan has made a ton of money...charge someone for the motor replacement...just unhook the battery after taking note of the unsuspecting customers radio settings...reconnect the battery and reset the stations...and then charge for a new motor and 4 hrs labor....for something that took 10 frikken minutes...what a forkin SCAM
Aug 20, 2002 | 09:27 AM
Have you tried it yet?
Aug 20, 2002 | 09:30 AM
BTW....
A past client of mine works for our local Nissan dealer. I told him that I was a little po'd w/ his service department. I also told him that I could let it slide if they were really that stupid, but won't let it slide if they are trying to take advantage of me.
He told me to write them a letter. I am going there in person. I just have to see the look on their faces when I confront them.
