Will Helical Limited Slip Differential make my 6 speed faster?
Old Aug 19, 2002 | 03:39 PM
2k2PhatMax's Avatar
Sold 2 99Silvermist SE :)
experts clue me in????
Old Aug 19, 2002 | 03:47 PM
6SPD_HLSD's Avatar
It depends what you mean "faster".
My answer would be yes and no.
Yes, because it will let you hook the car up better. A HLSD will split the power between two wheels more equally than an open diff.
No. It wouldn’t like a manual vs. auto.
Old Aug 19, 2002 | 03:53 PM
maxman00's Avatar
In other words
He is saying that it won't put more power to the wheels, like a manual over an auto, but rather give you better traction off the line.
Old Aug 19, 2002 | 04:15 PM
soundmike's Avatar
Very sound, Mike
And out of turns.
Old Aug 19, 2002 | 04:33 PM
2k2PhatMax's Avatar
sooo...........
so it would make my car have better traction on take off?
Old Aug 19, 2002 | 04:45 PM
maxman00's Avatar
yup yup
Old Aug 19, 2002 | 04:58 PM
2001SE's Avatar
if you can get HLSD...GET IT!!
Old Aug 19, 2002 | 06:14 PM
2k2PhatMax's Avatar
is it that good?
u have examples
Old Aug 25, 2002 | 09:37 PM
Cfbrenton1's Avatar
Re: is it that good?
I have the HLSD on my 6 spd titanium 2003. I would definitely reccomend it. It does make the car faster, because it decreases wheel spin. I have two maximas, on my 97, I will sit there and spin my tires if I am not careful. The 2003 is much more powerful, but I will get much more traction because of the HLSD. It will still spin via the clutch, but it will be just over the spin threshold. If you start from 5 mph, it will not spin at all. It will be just below the spin threshold. FYI, with the 6 spd, you can really squeel into second, and if you are good, you can chirp third sometimes.
Old Aug 25, 2002 | 10:42 PM
AznWontonboy's Avatar
Re: Re: is it that good?
Im not a pro on how Diffrentials work, but the way they reduce wheel spin is this:
when one wheel breaks traction easier than the other wheel, the diffrential feeds the power to the wheel that grips and vice versa.. anyone wanna correct me?
Old Aug 26, 2002 | 01:03 AM
Eleebob7's Avatar
I've got the HLSD on the 6-speed and didn't really notice any difference w/ or w/o it when i test drove. However, ur cornering will be a little better. I took onramps at like 45 when i could normally take them at about 35 so definitely worth the money.
Old Aug 26, 2002 | 01:12 AM
Re: Re: Re: is it that good?
I dont think it helps that way either.. it helps low speed cornering.. say you enter a turn slowly.. downshift to first mash the throttle.. normally your inside wheel would spin and outside wheel wouldnt do much.. the differential helps this...
Old Aug 26, 2002 | 02:00 AM
Eleebob7's Avatar
Re: Re: Re: Re: is it that good?
Thank you for the correction in my error
Old Aug 26, 2002 | 03:01 AM
Re: Re: Re: Re: Re: is it that good?
If that was a sarcastic remark, sorry. I shouldn't have put the laughing smilies up.
Old Aug 26, 2002 | 07:19 AM
soundmike's Avatar
Very sound, Mike
That's about right. Which would also mean, if both wheels have equal traction and there's a lot of power applied to both of them you're still vulnerable to wheel spin.
Old Aug 26, 2002 | 08:01 AM
jjs's Avatar
jjs
And just to throw in $.02...
remember that whatever traction advantage is inherent in the car, a BIG factor is getting a real set of tires and scrapping the stock ones!!
Old Aug 26, 2002 | 04:00 PM
Eleebob7's Avatar
Re: Re: Re: Re: Re: Re: is it that good?
No i was serious. I need to know what it's for cuz one of my friend's is gonna get an '02 max
Old Aug 26, 2002 | 04:13 PM
soundmike's Avatar
Very sound, Mike
Re: Re: Re: Re: Re: Re: Re: is it that good?
If your friend is an enthusiastic driver then he'll be better of with it. Otherwise, if he's your average Joe-shmoe he probably won't push the car to the limits of needing the HLSD.
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
sdotcarter
Sep 2, 2015 09:53 PM
Lowered_a33
Sep 1, 2015 07:49 PM
