tire sizes
Old Aug 19, 2002 | 04:13 PM
reggie's Avatar
tire sizes
i need new tires but im keeping my stock 17in se rims does anyone recommend anything. and does anyone know if i could put 235/45/17 on the stock rim. the stock tire size is 225/50/17, also does anyone have the bfgoodrich g force t/a kdws tire on their stock se rim. its a very good tire.
Old Aug 19, 2002 | 04:16 PM
y2kse's Avatar
There are literally dozens of posts on this subject, reggie. Do a search under tires and prepare yourself for the onslaught.
To make a long story short, 235/45R17 tires are not in-spec on the OEM 7"-wide rims. However, a number of people have run them on the OEM rims without a problem.
I don't care what you decide to do. But I would recommend that you do your homework before you make up your mind.
Old Aug 19, 2002 | 04:24 PM
MAX2000JP's Avatar
Re: tire sizes
I have the 235/45 G-force KWDS tires on my Max. They are awesome tires and I have had no problems with them so far. This includes tearing them apart road racing. Do your homework and make an educated decision.
jjames's Avatar
What An Excellent Question....
I think thin has been dicussed before, but just can't recall. (That smell is sarcasm).
Reggie my man, you are about to learn about the SEARCH button.
But, I will answer your question. Can you put 234/45/17s on your 17x7 rim? Sure. Is it a very bright thing to do? Uh, no. No, it is not.
I am guessing that you are asking because of the limited availability of 225/50/17. Try the 235/50/17. This will keep you in spec on your 17x7s. You may or may not find a bigger selection.
Beware. As I type this, there are several .org members licking their chops and getting to pounce on you.
Psst. In the future, use the search button. It'll save you from the abuse you are about to recieve.
Oh, and welcome.
Old Aug 19, 2002 | 08:42 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i decided to go with some michelin pilots a/s. i got them in 235/50/17 which stays in the spec, will make more contact and take up some of that wonderful wheel gap. they are a pretty penny but if you can fork it over, go for it. another good one to look at in that size is the pirelli p6000. check them both out over at tirerack
Old Aug 19, 2002 | 09:14 PM
Axel's Avatar
I had the P6000 for a year and I hated them. Also, if you look at tirerack's survey results for all the versions of the P6000 they're all 6.4/6.5 out of 10 for "Would buy again?" Not a very good result.
I currently have the Potenza RE730 and I love them. I haven't tried an enormous amount of tires so I can't compare them to much to other brands. I just know I love them.
Miket2006
Mar 1, 2021 03:55 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
Garrettz459
Sep 28, 2015 02:50 PM
