Correct octane
Old Dec 15, 2000 | 06:07 PM
martinf's Avatar
My owner's manual recommends octane fuel "of at least 91".
Premium is recommended, but "regular 87 can be used"
There is no 91 gas here, only 87 90 and 93. Should I be going up to 93?
Martin
5sp SE
Old Dec 15, 2000 | 06:13 PM
2000MaximaSE's Avatar
Yes, use 93
We used to get 94 here but i cant find it anymore... Now its 92 for me
Adam
Old Dec 15, 2000 | 06:14 PM
CIRCO's Avatar
Martin
5sp SE
You should be using PREMIUM gas to avoid any knocks, pings and anything of that sort. Also to put your sig on go to profile. It will prompt to a screen then just scroll down to signature.
Old Dec 15, 2000 | 06:43 PM
y2kse's Avatar
I use 92 octane in my 2K SE . . .
But my wife has run 89 octane in her 2K GXE for over 18,000 miles without a single hiccup or ping.
Old Dec 15, 2000 | 07:04 PM
tomz17's Avatar
Re: I use 92 octane in my 2K SE . . .
No NO NO NO NO NO NO NO NO... you are doing your car a GREAT injustice!!
It was designed for 91, give it 91... the kock sensor will allow it to work correctly with lower octanes, TEMPORARILY, but it is not a PERMANENT solution.. Don't use lower octane fuels.. You CAN cause damage this way!!
91 is ideal
anything more than 91 is fine as well..
FYI -> you can mix equal amounts of 93 and 89 to make 91!!!
Old Dec 15, 2000 | 07:33 PM
tomz17's Avatar
Actually IMHO, using anything less than 91 does run the risk of damaging your engine.. Especially over time!!
Chances are your car does "ping" (even though you may not be able to hear it). Nissan recommends 91 for a reason (if they could don't you think they would say "go ahead use 87"!!!?? --> sorta like Saturn does?? Saturn's big thing is "Our cars run on nothing BUT regular gas!!"
Just my two cents...
Originally posted by yo_its_ok
Never heard of regular gas giving any problems to the Maximas I've worked on. The cost of gas is too high, and all cars are able to run on regular, excluding supercars that do need it. A Maxima neeidng premium...unless you keep your car under "heavy" load...it's not worth it. BTW I use regular 89 octane on weekdays, 94 octane on weekends.
NOS Octane booster also helps, but worth very few octane points. All about how much you want to dent your wallet.
-Peace
Old Dec 15, 2000 | 09:21 PM
tomz17's Avatar
Well from what I understand (from this forum, and other sources) Engines [especially higher performance engines]are specifically tuned to run at peak efficiency on certain octanes, by achieving precise timings during combustion. (There's a lot of Math, Physics AND Chem involved here.. most of which escapes me at the moment)
Changing your Maxima's octane would therefore affect this timing (since as you imply, there is a difference in volatility between octanes...)
{actually, on a side note :: its a tad more complicated, because it turns out that the octane rating is a factor in determining the ability of unburnt end gases to resist spontaneous autoignition -> which has a very direct physical relevance to the way any combustion engine works}
Anyhow, I am led to believe that Nissan apparently understands that it's not a perfect world, and that all engines will knock, regardless of octane.. So they include a knock sensor, which should (based on detected knocks), retard engine timing to compensate..
I have also been led to believe that the knock sensor should not be used as a permanent solution which would allow one to use lower octane fuels in their Maxima..
I may be wrong, but no I am not pulling any of this info out of my a$$... just going on stuff I know, and have read previously.. It also seems counter-intuitive that Nissan would insist we use 91 octane fuel, if in fact, we COULD safely use 89 or 87!!.. I mean, especially with gas prices so high over here, and around the world!!!
tomz,
where did those words come from ?
as a technician I understand alot about cars and how they work. heck I've even gotten some useful info from Nissan techs working at the engine plant in Tenn. Everyone told me the same thing....Maxima's can run on regular no problem, its when you add more air to the motor, you're gonna need to add more fuel, and since all octane rating is just how "volatile" the mixture burns...the higher the octane, the "softer" the combustion is. More controlled....for me as daily commutting in the morning, no need for the fancy ****...come the weekend...time to let the Max's legs stretch...yeah 94 octane...nothing less.
Get your head out of your *** and don't preach to me that it'll run a risk of damaging my motor....absolut bull...heck you sound like a gas co. rep...
-Peace
Old Dec 15, 2000 | 09:26 PM
Tomz
your right. Putting 87 octane gas and letting your engine knock is not a solution. As in the FAQ page in the website, A knock senser detects knock, which means the knock already took place which will destroy your engine, and all it will do is to retard timming. Just stick with 91+ octane. Follow the Factory manual because no one knows your maxima like Nissan.
Old Dec 15, 2000 | 10:34 PM
y2kse's Avatar
Check it out . . .
From http://netnow.micron.net/~marriott/gasoline.htm :
"If you use a fuel with an octane rating below the requirement of the engine, the management system may move the engine settings into an area of less efficient combustion, resulting in reduced power and reduced fuel economy. You will be losing both money and driveability. If you use a fuel with an octane rating higher than what the engine can use, you are just wasting money by paying for octane that you can not utilise. Forget the stories about higher octanes having superior additive packages - they do not. If your vehicle does not have a knock sensor, then using an octane significantly below the requirement means that the little men with hammers will gleefully pummel your engine to pieces."
"You should initially be guided by the vehicle manufacturer's recommendations, however you can experiment, as the variations in vehicle tolerances can mean that Octane Number Requirement for a given vehicle model can range over 6 Octane Numbers. Caution should be used, and remember to compensate if the conditions change, such as carrying more people or driving in different ambient conditions. You can often reduce the octane of the fuel you use in winter because the temperature decrease and possible humidity changes may significantly reduce the octane requirement of the engine."
"Use the octane that provides cost-effective driveability and performance, using anything more is waste of money, and anything less could result in an unscheduled, expensive visit to your mechanic."
Old Dec 16, 2000 | 04:07 AM
wdave's Avatar
Martin
5sp SE
I tested this on an earlier Maxima. I ran several tanks of each octane,87,89,93. There was a noticeable driveability difference at each level. The amazing thing was that the mileage changed by the same percentage as the difference in price between the grades. Conclusion - not worth running the low octane even if potential damage is not an issue. BTW that was a few years ago, the percent difference in price between grades is less these days so higher octane could actually end up cheaper.
Dave
Old Dec 16, 2000 | 04:24 AM
Maxima-Ness's Avatar
I noticed the difference right off the bat when I first got my Maxima. The dealership of course gave me my first tank of gas free (they used 92 octane). I was like most people and just went for the cheapest gas when i pulled up to the gas station for the second fill up. I imediately noticed that I lost that "go" factor that I had before. It didnt occur to me that it was the octane rating causing this, but I quickly wised up to it and now only use the premium, no matter how much it costs! and my car is one thirst B*tch :-)
Old Dec 16, 2000 | 05:10 AM
wdave's Avatar
I just think there is too much stuff "floating" around when it comes to the issue of octane. Never have I seen so much tech talk in one thread. Makes me want to watch "Mr. Wizard" Maybe he knows the answer...
89 weekdays..Friday night if its close to E, fill it with 94, have some fun
I WANT REAL PROOF...I WANT DYNO RUNS, SENSOR READINGS, KNOCK SENSOR VOLTAGES, EVERYTHING...I WANT ALL THE DATA, THEN LETS FIND OUT WHAT IS BULL AND WHAT IS NOT
-Peace
You have the car, go ahead. I have seen it on the chassis dyno I owned, and had enough experience over the years to know that octane is octane and most of the rest is myth. The determining factor is how far the spark will advance given high enough octane, that limits the benefit. I doubt that the Max goes much beyond the advance for 91 , most likely 94 or 99 would do nothing.
In the "old" days you could play with timing. I did. I also replaced a lot of pistons. I wouldn't run wot on my Max with 87 octane. 89 is close to the recommendation but if you check mileage and crunch the numbers you'll se it doesn't save $ over 93.
Incidentally, Click and Clack addressed this very issue on "Car Talk" about three weeks ago.
Dave
Old Dec 16, 2000 | 07:13 PM
tomz17's Avatar
Bah Humbug...
My baby drinks the good stuff... Why would you buy a $20+k car and then pinch pennies on gasoline.
Oh Blah....Enjoy the Ride...
-Seasons Greetings...
litch
123
Jan 4, 2024 07:01 PM
leatherneck
Sep 30, 2015 09:16 PM
JoshG
51
Sep 21, 2015 10:41 PM
cruce91
Sep 20, 2015 10:23 AM
sdotcarter
Sep 2, 2015 09:53 PM
