how to modify positive connector to fit optima battery
Old Aug 30, 2002 | 03:41 PM
MaximaZero's Avatar
Needs non-Maxima Friends
does anyone know how to do it? i was searching for a post that said how to, but cant find it anymore.
Old Aug 30, 2002 | 07:23 PM
BigDogJonx's Avatar
Re: how to modify positive connector to fit optima battery
What has to be modified? The deep cycle batteries come with both top post and side posts. Only thing is that the top posts are sort of closer to the front of the car instead of the other side. You might have to extend the wires at the most.
Dixit
Old Aug 31, 2002 | 10:14 AM
serin's Avatar
kevin posted something about putting a perch underneath his red top to lift it up above the lip. other than that, i didn't know a mod was required.
Old Aug 31, 2002 | 10:15 AM
serin's Avatar
keep us posted on what you end up doing, cuz i'm looking to get a red top myself.
Old Aug 31, 2002 | 03:33 PM
mingo's Avatar
ken, after i get my car back u can swing by and look at what i did. but u also need to get a 0 gauge connector ring with a crimper that can crimp it too
Old Aug 31, 2002 | 04:02 PM
cobymoby's Avatar
1 week after I bought my car I tried to migrate my Optima red top over to my Max, I ran into the same problem with the positive top post being too far "in" on the battery (the maxima positive harness is not long enough.
There are three solutions:
1. They have post extenders that you can put on the battey
2. Cut the factory battery clamp and put a longer one on there.
3. (and I think the best solution), I contacted Optima, and they make an orange top that has the battery posts that extend farther to the edge of the battery, thus, the nissan harness will fit.
Old Aug 31, 2002 | 10:22 PM
MaximaZero's Avatar
i ended up chopping up the black piece of plasitc and stretching the cable a bit. i just barely makes it, and is kinda bent.
here's a pic of keving's:
i'll try to take pics of mine later and post them.
Old Aug 31, 2002 | 10:25 PM
MaximaZero's Avatar
a lil off topic question:
typically, how long does the stock battery last before it needs replacement? my mom's (from a 97 i30) lasted for 5 years and now barely holds a charge. that's why i put the optima in my car, so that she can take my battery.
i just want to know if that's about the typical lifespan of the battery. thanks!
Old Sep 1, 2002 | 02:53 AM
mingo's Avatar
i dunnno man i killed two stock batteries within' 1 year and a half.
Old Sep 1, 2002 | 03:48 AM
cobymoby's Avatar
I was going to do the same thing, someone else here had suggested it but I decided against. At the time I didn't have a system, but that's about to change this week.
James92SE
Oct 8, 2015 04:57 PM
markevans999
Sep 10, 2015 04:29 PM
