6 sp vs. 02 GT mustang (not cobra)...
Originally posted by tbirdrob
I traded a 1999 5-speed GT for my 2002 6-speed Maxima. The Mustang was faster, period. And for those who believe the Max has the advantage from a rolling start, it doesn't. Rolling starts give the advantage to the car with the most torque (given similar weights and gearing). The reason is--it takes less time to spin the engine to peak power when it's doing so with more torque. Car mags created the 5-60 mph test just so the high-torque American cars would have something they could show off. With 302 flt lbs of torque, it doesn't much matter what gear you're in, you get right now acceleration.
Conclusion: you raced an automatic or an unskilled manual driver.
Originally posted by MAX2000JP
If you want a project....Find yourself a Miata and drop a 5.0 in it for the ultimate sleeper. They make a kit for the conversion that I believe I saw in Grassroots motorsports.
Originally posted by 95/2k2:6Maxima
I beat a SS camaro from a roll he even said go. I lost from a stop. The 2k2 and the mustang GT from a roll should be about the same. The rolling start test is real world acceleration. The GT will not have an advantage. It does however have the from a stop advantage. Its called rear wheel drive. Just like the SS beat me from a stop. No traction.
I can see your argument with the stang, and I agree that from a roll an 02' max vs. 02' stang would be interesting. However, you saying that you beat an SS? These cars dyno at about 300hph at the tires, thats 80-90hp more than most 02's out there!! Not to mention that they have unbeleivable torque which we don't have.
OK, OK....
There truly is ONE AND ONLY ONE way to determine which car is faster...
ONE experienced driver is selected and that driver does back to back runs in both cars. One will be the faster (in categories like launch, 60 foot times, elapsed time, trap speed....and then an overall 'winner' can be deduced). That takes out driver ability as a factor.
Then the whole world knows which car can beat which car.
After that, threads like this can truly focus on what people don't like to admit...that some wins are against people not really racing or not really driving.
Originally posted by 2K2_6spd
Well stay away from AZ and TX then, cause there are a ton of 96+ Stangs that will stomp a mudhole in your a$$. Speaking of poor driving, what's with that 13.2@107?? And WTF is an ATX???
I never claimed to be superman behind the wheel of my Mustang...did you read that some place? 13.2 at 107 is due to two things...drag radials and me not being the best launcher in the world. My car, with an experienced (I only go 1-3 times a year) track driver, will run mid to high 12's and I know that...never claimed I was John Force. Somehow at the 4 autocrosses I race in a year, I am able to beat all but one Viper, All the Corvettes, All the Cobras, Some of the M3's, All the SHOs, and most of the rest of the field so I must be doing something right...but a pro drag racer I am not.
An ATX is an Automatic...Old SHOTIMES forum talk. Don't know why that worked you up so much.
As far as bad driving...until your 6 spd can go faster than my wife's Autotragic ATX or what ever you want to call it I wouldn't Sh*t on my driving...I never did on yours.
Originally posted by 2000 SE
Well that is the problem! If you raced from 60 he should not be starting in 3rd much less 4th. It sounds like he really doesn't know how to drive, which is probably the reason you "beat" him.
"Driver makes all the difference" doesn't mean your car is faster like we are all discussing.
Bosssho,
I ran 14.2 at 98mph with nothing done to my 00' GT, and 14.0 at 100.5 with x-pipe and cone filter.
Bosssho,
Stock and Modified GT
Here is a whole list of stock and modified GT times 2v and 4v
http://forums.stangnet.com/showthrea...hreadid=201999
I was just trying to see if you woud respond back Bossho
So your wife's Max ran a 14.5 what? Lets see the slips too, cause I'm calling B.S. on a 14.50 in a STOCK automatic Max.
Good luck with your Max and hopefully we'll both hit the 14.2 to 14.3 range when the temps and humidity are more accomodating.
Interesting read, nice to see all the misconceptions out there.
Your average '01+ GT is going to dyno at about 230-35RWHP/280-285lb/RWTQ and run anywhere from 13.6-14.0 with a great to decent driver. The '01's run a slightly higher compression from the '99-'00's for a few extra ponies.
Here's a clip I made yesterday of a 0-60mph run on a flat road with traction control off in my 5 speed '01 GT. Accelerations begins into 9 seconds and she moves from 0-60 in 5 seconds flat. >> short vid clip.
So much for that 6.X crap. Some magazines don't want to hammer 'em down and spin the tires enough. Perhaps that's why they also got a 13.4@116 with an 11 second Cobra R.
I have never seen a sub 14 second 99+ GT run at the track. My friend Neal who has been to many midwest tracks has not seen a stock GT running 13's. Yes I read about these 13 second stock GTs, but I have yet to witness one. Everytime I go to RT 66 there are a plethora of 99+ Mustang GTs and it seems like they all run low-mid 14s in manual form. Since when did a Cobra R run 11s?????
It's mostly the 01-03's running high 13's. It's rare over on MustangWorld.com to not see one in the 13's yet.
And here's to the guy talking smack about the not going over 139. The new GT's with Z rated tires are governed at 148.
Here's a 94-5 5.0 >>
I looked at that vid....0-60 was about 6 seconds. You started at around 8.75 seconds and you hit 60 near 14.75.
http://www.fordpower.net/forums/show...&threadid=7506
6 seconds, huh? Perhaps you're hellbent on not coming to terms. Check your glasses >>
Im not trying to be a ****....but it was anywhere between 5.75-6. You started BEFORE 8 seconds....look at the needle. I stopped the tape when you hit 60 and it was right before the counter hit 15 seconds.
9.3 to about 14.6.
Bah, not much point in bickering over a couple tenths when the point is proven.
I'll leave the happy Maxima soccer moms alone now.
Before 8? Really? No.
9.3 to about 14.6.
9.3 to about 14.6.
Thanks....And Ill leave the redneck Mustang owners alone now.
9.3 to about 14.6.
9.3 to about 14.6.
But I still like the look on that **** in older body 5.0 Rustang as I pulled and pulled on him. He was defintely surprized of the sound my car made
And the funny thing was after I slowed down he caugth up to me and then made his rear swing out at this turn and almost lost control of the car. What an idiot.
Originally posted by ford5litre
14.5 is not unbelievable for a stock automatic. I used my G-Tech Pro and got to 60 in 6.4 seconds and a 14.99 quarter mile in my auto. I did only 1 run and I didn't really rag on the car too much... Also, the temp was in the 90's and humidity was waaaay up (I live on the coast).
2k26spd and I already squared this away and as it was already pointed out with no argument there is a stock Auto 02 running 14.4 which I hope to better come this fall with my wife's 02. Hell, even C&D was able to get an 02 6 spd down to 14.7 at a great 97 mph...that's good for them.
Originally posted by bosssho
lol, Wasn't talking smack...just talking facts. You are right though, I checked, and the 02 and up GTs will run over 140...144 is the number I seem to see for a top speed...over 150 is pretty damn good for a non cobra...course many Max guys have gone over what the magazines claim a 6 Spd Max can do for a top speed so hey, if a GT can run faster than 144 now, great. I have a 160 Speedo in my 87 and I have burried it a few times, but until I GPS it, I won't kid myself that I have actually gone that fast. As a point of reference, I snow mobile and a lot of people claim their sleds will do 120 + Mph and when they are Radared or GPSed it's more like 95-105 mph.
That is pretty fast, I rented it once at and it was pretty scary. Can't imaging going that fast.
Originally posted by Dany
Woa, 120+ mph on snow mobile
I haven't gone 120, I was saying that as a speed point of reference. The fastest I was clocked on a sled was 108 mph up in Canada on a road we closed off for a one mile run. It felt awesome and if I had another 3 miles to run I may have gone 110 at the most.
9.3 to about 14.6.
9.3 to about 14.6.
BTW - Why are you even over here on a "Maxima" forum???? Maybe your big bad mustang ego feels threatened by out 6-cylinder sedans......I don't blame you...I'd be ****ed too if I had 2 more cylinders and a little more than a liter more displacement, and they were keeping up with me....
jerrod99_se-l
Sep 25, 2015 03:02 AM
