Maxspeed springs & stock shocks = bad tire wear?
Old Sep 4, 2002 | 05:51 PM
e28fixer's Avatar
I installed Maxspeed springs with stock shocks in May along with OZ 17x8 rims and new Kumho 712's (235x45). I had the car aligned at the same time and kept an eye on inflation. Except for a little bounce due to shocks a bit weak for the new springs, I was very pleased with the new look and the handling. Now 3 months and 1 tire rotation later all 4 of my tires are feathered on the outside edges (somewhat on the inside) and the car sounds like a 4x4 coming down the road. It's infuriating. Any chance the stock shocks coupled with stiffer/lower springs simulated worn suspension and caused the VERY premature tire wear? Thanks for any info.
Scott
2K SE
Old Sep 4, 2002 | 05:56 PM
soundmike's Avatar
Very sound, Mike
From what i gathered here, alignment should have been done a couple of weeks after spring installation - this will give your suspension time to settle in.
Chances are, after installation the alignment was fine. But after settling in the alignment might have changed a bit.
However, what you say about all 4 tires having uneven wear is confusing me just a bit. I always thought, if any, that only the front would have uneven wear given that the rears can't be adjusted as far as alignment goes.
Perhaps it's the way the rims were installed?
Old Sep 4, 2002 | 06:24 PM
maximadave's Avatar
detailerdaveb@gmail.com
How many miles do you have on your 2K? If its a little high, replace the struts. I have a 2K2 w/Maxspeeds with no problems yet. (Knock on wood). And yes, I'm running on stock struts.
Old Sep 4, 2002 | 06:26 PM
asu174's Avatar
Clay Aiken has fancy genitals
My Kuhmos did this too. No offense, but Kuhmos are crap.
I know this doesn't help you, but I'd put blame on the tires. I hate Kuhmos.
Old Sep 4, 2002 | 06:29 PM
e28fixer's Avatar
Just under 33K miles at the moment. I bought the Kumho's based on good reviews at TireRack. They aren't Pilot Sports but certainly this kind of wear is out of the ordinary - even for Kumho's.
Old Sep 4, 2002 | 07:18 PM
maximadave's Avatar
My rommate drives a C43 Mercedes with 18" Brabus wheels wrapped with Kumhos and he is getting bad tire wear on all 4 tires. How many miles do you have on the Kumhos?
Old Sep 4, 2002 | 07:30 PM
asu174's Avatar
Mine lasted less than 20,000 miles before MAJOR wear occurred. They are complete junk. Get some Nittos (if you live in a dry area). Otherwise, some Michelins would be cool......
Old Sep 4, 2002 | 07:31 PM
WizzaMax's Avatar
It's the tires dude...
Old Sep 4, 2002 | 11:09 PM
Gunner's Avatar
the outer edge on my front tires wore pretty quick after the maxspeed install w/ no alignment. i swapped the fronts to the rear bout a week ago.
Old Sep 5, 2002 | 02:32 AM
melteye's Avatar
I bought Kumhos... I guess I'm a moron.
http://www.melteye.com/12.jpg
too bad my car is dying... my poor poor car.
Old Sep 5, 2002 | 11:35 AM
victor's Avatar
maybe it's the offset on the rims..
Old Sep 5, 2002 | 11:50 AM
e28fixer's Avatar
Not that. I double-checked with OZ to confirm that I got the correct offset and bolt pattern prior to purchase. I'm beginning to believe the tires may in fact be the problem.
Old Sep 5, 2002 | 08:29 PM
victor's Avatar
those tires must really be out of wack.
Old Sep 6, 2002 | 11:53 AM
tkarrh's Avatar
No problem with my MaxSpeeds w/stock shocks are just fine. Had on for about 5000 miles.
Old Sep 6, 2002 | 11:56 AM
e28fixer's Avatar
Was just informed by Kumho that the tire pressure NTB told me to run (29/29) was way too low for my application. Apparently I should have been running 38-40psi with my 235/45-17's on 17x8 rims. I guess that would explain at least some of the wear. It looks like I'll have to suck it up and live with these as long as I can. I just HATE loud tires...
Old Sep 6, 2002 | 01:33 PM
asu174's Avatar
The tires will only get louder. Go do some burnouts in the parking lot and buy some Nittos.
Old Sep 6, 2002 | 01:37 PM
MaximaMan77's Avatar
You should about ready for new shocks and struts. They die slowly you'd be amazed how the ride feels on new ones. I don't have any experience with Kumho's but I'll take every one elses word that they suck. I will tell you I liked my Nitto's.
Old Sep 6, 2002 | 05:33 PM
victor's Avatar
i heard the nitto 555's are geared more toward track than street, and they might be loud. but that's just what i've heard. i personally like the way the tire looks and the price is reasonable.
Old Sep 6, 2002 | 10:38 PM
Y2KMaxGXE-R's Avatar
I am running Kumhos on stock suspension for 7K miles already and knock on wood, dont have that kind of a problem. Your tire wear may depend on your driving style as well, if you like taking those corners fast, you'll get more outer wear.
Due to my past experience, I would not take my car for alignment to NTB.
Old Sep 6, 2002 | 10:40 PM
KLOOGY's Avatar
L33t BMW Drivah
Ive got about 5K on my Maxspeeds.. and another 3k on my 19's...no problems whatsoever ! ..So far !
Old Sep 7, 2002 | 02:23 AM
melteye's Avatar
Ok... My Kuhmos are silent... But what tire pressure should I use. 18x8.5... 245/40/18
Old Sep 7, 2002 | 04:52 AM
asu174's Avatar
Your Kuhmos are alos a week old. After about 15K-20K, mine were very loud- AND worn.
Old Sep 7, 2002 | 04:54 AM
melteye's Avatar
Sucks for me
Old Sep 7, 2002 | 05:58 AM
asu174's Avatar
Sucks for me
You can't sleep either?....lol
Old Sep 7, 2002 | 05:59 AM
melteye's Avatar
Never can. How about you? I generally go 2 days then sleep, go 2 days then sleep... My routine
Old Sep 7, 2002 | 06:27 AM
asu174's Avatar
My issue is that I wake up at 4AM no matter how late or early I go to bed- or how much Benadryl or Ny Quil I take the night before either.
Old Sep 7, 2002 | 03:14 PM
melteye's Avatar
Try sleep aid and Nyquil together. Or Alchahol and Nyquil. When I used to work at Home Depot I was forced to do that so I could go to sleep.
I don't think it's very healthy though
Matt93SE
May 24, 2019 02:58 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
homeyclaus
Sep 3, 2015 06:15 PM
FlaMark
25
Aug 28, 2015 10:15 AM
