Z manifold swap revisted, it is now going down!
Hello guys I just spoke to Ken from JRnissanparts, he was very helpfull giving me a quick quote and awesome prices. I just ordered all the parts threw him @ 30% off(septemeber special). If you recall the G35 parts where about $580, the same parts are about $450 threw him.
They should be arriving in about 1.5 weeks. At that point I am going to keep my fingers crossed and hope they fit. They should I'm almost positive of it. Then I will head to the dyno and pray for some nice gains, hehe.
I will keep you folks updated!
Can you say 250 FWHP NA?
Re: Z manifold swap revisted, it is now going down!
I'm confused... 4th gen Max's wanted the variable intake from the Cefiro for the hp increase... now the 5th gen has it and we are trading it out for a non-variable intake from a Z?
I know I have this wrong, can someone clarify?
Originally posted by SR20DEN
People trade thair intakes for the VI to have the best of both worlds (low end and high end tuning). The VI (VQ30 VI) has a much better top end on it than the VQ30 normal intake. In this case Ethan and I beleive that the Z intake, although not a VI, has a much better top end on it than the VI that we currently have. It's all about the end results. He is willing to trade in some low end grunt for a hefty top end hp gain. Thats the plan anwyays.
Re: Re: Z manifold swap revisted, it is now going down!
Originally posted by MAX2000JP
Sounds like a good mod. I dont know if it will get you close to 250WHP, but it should get you around 240
Your a sick sick puppy emax95!
Are you sure you didn't accidently buy a Max, because you got the ***** of a Honduh owner. I swear those guys are crazy spending $20K+ on a $5K car.
Anyways, it's guys like you, Kev, MardiGrasMax, SR20DEN, and others who PIONEER this hobby of ours.
Keep it up!
Keep it up!
Originally posted by MaxSE2k
Can you re-post what the parts were that you were getting? Is it just the intake manifold & injectors?
IceY2K1, lol you cracked me up
didn't the 350z dyno in the 240 hp range in a recent magazine? I thought it also had different cams and a more header-like exhaust than the maxima. I remember the graph of the dyno looked exactly like a 4th gen max curve until about 5600-5800rpm, the the hp started going up again really steep, so something is happening right there at that point. I guess hopefully that is what resonance the intake is tuned for and you will see some gains. I am with Kev though...3hp.
And also the Z "heads" and "cams" are identical to the maximas..I have a very high flowing exhaust and intake at the moment and the Z's motor is the same as mine(and all 3.5 VQ's for that matter). theres only 2 places left where the other 28 WHP is. Thats #1 the intake manifold and possibly( although I highly dowt it) the ECU.
DrVolkl, I see no reason why the CPU wont handle a new manifold considering nothing electronical is being controled by eitehr intake manifold. Only difference is the MAFS will read a higher amount of air traveling into the motor. And luckily our MAFS is the same as the Z's. So again there wont be any problem there.
Matticus, Heads and all are exactly the same.
mzmtg, you brought up a intersting point. "The hood clearance" It is my only concerne at the moment. Worse case senario is I will have to have a scoop put on the hood. But in all likely hood I expect it to fit.
And thanks for your kind word and supports guys.
you wont have as an efficent an engine. You always want an intake to get as close to that number as possible on the high end becasue the inertia of the air actually can over fill the combustion chamber from what it normally would be.
And if you don't think an intake manifold alone can add heaps of top end HP then you should argue with Sprintmax about it for a few hours.
Now that's hitting below the belt.
Thats fine, you can be with Kev on this one but keep in mind he was only joking. Are you joking too? I hope so becasue a guess of only 3hp sounds very pessimistic and a bit uneducated.
I amk not an expert on the VQ, but due to my work on LT1's and 302's....I just think the HP gains on the Z are from a cobination of Manifold and ECU changes. I have a feeling most of it comes from the ECU . Look at the design of both manifolds.. I might be wrong, actually I hope I am .
Originally posted by asu174
What is the net hp prediction on this? 8? 10?
15-20 FWHP is my esitmate. Who knows though. If I am wrong then some huge gains can be expected form a simple ecu modification( I dont buy that idea though).
I'm next in line for this mod if you net 10 hp+ at the wheels.
So if I'm reading this thread right...
You guys said the 350Z didn't have any gains from the cams, because the parts are the same. I got that part.
My question is...Some other magazines had said before they drove the 350Z that the power difference would probably come from using the CVTC on the exhaust cam as well. The Maxima, Altima and G35 are just supposed to have CVTC on the intake cam. Does anyone know if Nissan really did this or not? It might be working in combination with the manifold for that top end power you guys were talking about. Just a thought.
Re: So if I'm reading this thread right...
The 350Z does not have CVTC for the exhaust. It is mechanicaly identical to the maxima except for the intkae manifold and of course exhaust.
asu174, this definatly wont work on 2000-2001's. You guys use a throttle cable, 2002 + does not. We have a electric drive by wire throttle. This allows us to move the TB any where and just plug the wire into it Incase you did not know the throttle body is going to be moved quite a bit to addapt to this intake.
Re: Re: So if I'm reading this thread right...
In case you did not know the throttle body is going to be moved quite a bit to addapt to this intake.
Then remove one of your foglights, run a custom pipe down to the opening,, and Muhahahahaha......... Ram Air baby !
The CVTC device is only attached to each intake cam but the Exhaust cams are slaved off of them. Therefore the cam timing is changed on both cams at the same time. This is true for the VQ35DE's in all of the cars not just the 350Z.
It was once mentioned that the 350Z was supposed to have a slightly higher valve lift than the Maxima so maybe the journalists got ti mixed up. If the 350Z does indeed have a higher max valve lift then we need to check on the lifter part numbers and see if a difference is there.
