My MAX keeps stalling!!!!!!!
Old Sep 6, 2002 | 07:22 AM
ArcticMax's Avatar
This is a very serious problem.
Car= 2000 GXE 5-speed. CALI SPEC.
Mods= Berk Tech HAI, Cattman Y pipe.
Problem= constant stalling.
Whenever I put the car in neutral, or press the clutch, the engine just dies.
I would be cruising, and I would pop the tranny in neutral cause there is a red light ahead. Now, the RPM would start dropping since the car is in neutral, BUT, it drops all the way to ZERO and the car just dies.
This happens at least 5 times a day whenever I'm on the road for more than an hour.
Couple times, I almost crashed the car because it happend while I was on a ramp. I was in a snake curve, and the steering just went dead cause the car stalled. I almost crammed the car straight into the guard rail.
I'm gonna put the factory intake back on and take it to the dealer in a few days.
MY CEL is also on right now. I pulled the code from AutoZone, and it turned out to be an oxygen sensor. Bank 1, sensor 2.
Does anyone else have stalling problems
Old Sep 6, 2002 | 07:45 AM
Cutler's Avatar
Remember I told you it was doing that at the track, sounds like you are having a timing or an idle speed issue. Try the stock intake and take it to the dealer, they will see what is up when they run a diagnostic test on it.
Jason
Old Sep 6, 2002 | 10:58 AM
Y2KMaxGXE-R's Avatar
did you disconnect your battery while installing your intake? How about doing it right now, disconnect for a half hr to reset your ECU?
I had the same problem after installing the Berk Intake, but it took only a few mile test drive for it to "learn" to keep the idle speed.
Old Sep 6, 2002 | 11:46 AM
tkarrh's Avatar
try cleaning the throttle body. I had the same problem. First my MAF connection was loose. Still had the smae problem, then I cleaned the throttle body no stalling.
Old Sep 6, 2002 | 05:21 PM
Max2000's Avatar
I have that problem once in a while.... please let me know if you find the answer.....
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
