2002 ECM Upgrade?
Old Sep 9, 2002 | 12:20 PM
2002 Maxima SE's Avatar
2002 ECM Upgrade?
I just called my dealer to set up an appointment for my new O2 sensor to be installed. Long story short, they did not have the sensor and had to order it. Well, the dealer says that I am scheduled for an ECM flash as well. I asked if it was an upgrade to the existing ECM code and he said, "Yes.". Anyone know anything about this? I am guessing that the reason my O2 fouled was due to an ECM error and this will correct it.
Old Sep 21, 2002 | 01:04 PM
ABS's Avatar
ABS
Re: 2002 ECM Upgrade?
Anything happen with this? I am curious to know if there is an ECM update for 2K2. Also, if you received the flash, did you notice any change in engine performance?
Old Sep 21, 2002 | 01:10 PM
emax02's Avatar
Re: Re: 2002 ECM Upgrade?
25 FWHP
Old Sep 21, 2002 | 01:11 PM
ABS's Avatar
ABS
Seriously!
Old Sep 21, 2002 | 05:58 PM
25 FWHP
I wish! Well, it must be important. I went in on a Saturday to get the O2 and reflash. They had a problem downloading the reflash from Nissan so they just changed the O2 and sent me on my way WITHOUT resetting the SES. I asked them if they could reset it and do the reflash later and they said, "No". I asked what the reflash was for and they said they THINK that some of the parameters were to tight and Nissan loosened them up. I asked if the old ECU code might foul my O2 sensor again before I had the reflash and he said, "No".
Weird. I think the parameters for emissions were real tight, so that if the O2 was off by a degree it would set of the SES light. The car appears to handle the same. I would like to find out exactly what changed though because my dealer was grasping at straws.
Old Sep 22, 2002 | 09:52 AM
ABS's Avatar
ABS
What is the build date for your car? It might be possible to call Nissan North America and find out if there is actually a flash available for your car and what the changes are . . .
Old Sep 22, 2002 | 01:30 PM
I would have to check, but I bought the car in late September of 2001.
Old Sep 23, 2002 | 09:52 AM
ABS's Avatar
ABS
Does anyone know how to tell what version/release of the ECM code is running on any given 2K2/2K3 ecu?
Would the Consult II or GST show a version number?
How are ECM updates obtained/applied to Nissan ECU's?
aw11power
Oct 10, 2021 04:57 AM
MaxLvr21
Oct 17, 2015 12:11 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Marc2theMax
Sep 28, 2015 08:13 AM
