tails idea
tails idea
Is it possible to have your rear turn signals always be lit up? So if you have red turns, at night you have a red circle of light, instead of a semi-circle. And when you put your turns on, the turn portion of the signal just blinks. When you hit the brakes, the turns light up too. I think a circle of red light looks better than the half circles. Just wondering if you can do this...thanks.
Re: tails idea
[QUOTE]Originally posted by vinnieloo
[B]Is it possible to have your rear turn signals always be lit up? So if you have red turns, at night you have a red circle of light, instead of a semi-circle. And when you put your turns on, the turn portion of the signal just blinks. When you hit the brakes, the turns light up too. I think a circle of red light looks better than the half circles. Just wondering if you can do this...thanks.
good idea newbie make it happen!!!!
just run a nother light in to the turn signal housing and run it off the brake light that way it would all light up red and then run a nother bulb off the turn signal and put it in the brake light housing so the top will blink with the turn signal. then all is red and all blinks red? well thats my 2 cents
tarun900
19
Dec 20, 2021 06:57 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
