Rear Windows
Old Sep 18, 2002 | 04:34 AM
Bulldawg's Avatar
Rear Windows
Is it possible to modify the rear windows to where they will roll all the way down? I am tired of hearing ppl b!tch when they try to roll my windows down. As anyone succesfully done this?
Old Sep 18, 2002 | 04:37 AM
BigDogJonx's Avatar
Re: Rear Windows
Dont think it can do all the way down, there is a limitation on the door itself on how much of the window it can hold.
Dixit
Old Sep 18, 2002 | 06:59 AM
jjs's Avatar
jjs
Yep...
it cannot go down farther...there have been threads on this...
Old Sep 18, 2002 | 12:03 PM
Triple8Sol's Avatar
I miss the .org!
I remember somebody actually took apart the door and checked. Apparently, due to the space/design, the back window cannot go down all the way.
Old Sep 18, 2002 | 12:11 PM
NickStam's Avatar
Old Sep 18, 2002 | 02:19 PM
SkyDaver's Avatar
Look at almost any four door car from the last 20 years or so.
There is a curve, or cutout, at the bottom rear of the door, where it goes around the rear wheel well.
The bottom edge of the rear window really must stay inside the door, so the window can't go any lower than that.
If the automaker wants a window that will go all the way down, the passenger compartment has to be longer so that the door doesn't have to go around the wheel well.
They could shorten the door, but that makes it more difficult to get in and out.
They could put in a fixed window in the rear of the door, and move the track farther forward, but that means that the window isn't as large (and the styling might look pretty ugly.)
Old Sep 18, 2002 | 02:32 PM
ms.thicknes's Avatar
I've seen some cars where the back windows goes down at a sharp angle instead of straight down...which circumvents the wheel well prob.....
Old Sep 18, 2002 | 02:35 PM
MaximaMan77's Avatar
You could try 1 of these:
Take off your sunroof wind deflector and when someone b|tches roll all the windows up open the sunroof and haul a$$
Or when someone b|tches tell them to STFU or get out and walk
BTW SkyDaver's answer is right on the money.
Old Sep 18, 2002 | 05:06 PM
SkyDaver's Avatar
Not wanting to sound sarcastic, but what car? If it goes down at a sharp angle, what about the front edge of the window?
Old Sep 18, 2002 | 05:10 PM
burma's Avatar
The rear windows on the Acura TL go down all the way.
Old Sep 18, 2002 | 05:12 PM
Y2KSESteve's Avatar
As do the G35 windows.
Old Sep 18, 2002 | 06:12 PM
truthfully I didn't even notice the model..... I was too busy checking out the windows......but the next time I see it I will make a note of it!!
Old Sep 18, 2002 | 06:24 PM
Kojiro_FtT's Avatar
Cuz the wheel is far enough back that it doesn't interfere. It also allows for a roomier backseat.
You are screwed on the Max.
Old Sep 18, 2002 | 06:25 PM
Ludacris's Avatar
2nd gen Integras had this, so did 1st gen LS400s...window goes down at more vertical angle to take less space in door
Old Sep 18, 2002 | 06:30 PM
perrymaxima's Avatar
The 92-96 Lexus ES300, is one car that window go down in an angle they look as if the rear windows are broken when they are all the way down cause they tilt. I don't like that look at all
matts95max
Apr 23, 2025 10:44 AM
The Frye
Feb 3, 2019 08:34 AM
markevans999
Sep 10, 2015 04:29 PM
ef9
Sep 5, 2015 11:18 PM
maximusrising
Sep 4, 2015 06:31 PM
