Digital Climate Control
Old Sep 18, 2002 | 06:07 PM
importspeed24v's Avatar
Have any of you changed over your analog control to a digital one? I have a non-bose 2k2 and was wondering if it can be done and how much of a PITA it is....anyone?
Old Sep 18, 2002 | 06:29 PM
2k2.6spd's Avatar
i have the auto climate control..its NOT the greatest thing since sliced bread. in fact im somewhat dissapointed with the a/c. i doubt it would be different with either one however. why do you want to change ?
Old Sep 18, 2002 | 07:18 PM
bsetiawan's Avatar
Re: Digital Climate Control
I wanted to change mine a while ago but it is not as simple as changing the control unit only. There are more sensors and wirings for the digital climate control compared to the analog one. To me, it's not worth the effort to modify it.
Old Sep 18, 2002 | 07:23 PM
2001SilverSeMax's Avatar
What's so bad about the A/C? I have the auto climate control, and it works great.
Old Sep 18, 2002 | 07:38 PM
Dario's Avatar
i was planning on doing this myself but havent found one used yet on ebay did a while back ago but lost the bidding.
Old Sep 18, 2002 | 07:44 PM
KL99SEA's Avatar
I got the auto climate control and do not like it either. I live in Fla and its always 85 plus, if you leave it on auto it blows on high like forever so you manually turn the blower speed down. I liked the the manual one I had on my 99 better. Anyone know if you can read interior temp on the trip computer or just outside temp?
Old Sep 18, 2002 | 08:04 PM
If you have it set on 60 degrees, the fan will keep blowing on high until it gets the interior to 60 degrees. If you're having to turn the fan down earlier, then it hasn't reached the interior temperature yet. I think this feature works great. On summer days when the interior is well above 110 degrees (black leather seats), and I set the Auto Climate Control on 65, it blows on high and once it's at 65 in the car, it goes to it's lowest fan setting. Simple as that.
Old Sep 18, 2002 | 08:09 PM
Kojiro_FtT's Avatar
Just outside temp. If you got the temp/compass mirror option, that shows inside temp.
Old Sep 18, 2002 | 08:56 PM
Dany's Avatar
I had a question about climate control too.
When on Auto, it will only be in one mode right, arrow pointing to the face? It will be cool if it adjusted the mode too.
I think on my friend's 99 Maxima, when you set it to Auto it will start from the arrow pointing to legs and when switch over to arrow pointing to face.
Old Sep 18, 2002 | 09:32 PM
ajahearn's Avatar
another problem with climate control
is that you can't set the high and low, only the average with less than a few degress of variation. If you live in a place where the temperature swings a great deal (northern california) this is a royal pain. In the morning the heater blows when you don't want it to, and in the evening the a/c blasts on even when its nice outside.
Has anyone figured out a way to adjust the temperature range?
Old Sep 18, 2002 | 09:39 PM
CO2kmax
With auto it will change modes, at least mine does. When I have the heat on and it gets above a certain temp it will change to floor and dash, and blow out colder air. Mine works great I love it.
Old Sep 18, 2002 | 10:18 PM
emax02's Avatar
If you wanna do the swap you need the actual claimate control unit and 3 sensors. I have been thinking about doing this a while my self. The wiring is probably allready all set, you just need to get the proper sensors. Maybe I will do this sometime and do a write on it. It should be fairly cheap to do if you get the stuff out of a junk yard.
Old Sep 18, 2002 | 10:28 PM
emax02's Avatar
www.car-part.com has quite a few auto climate control modules for $100. Hmm.. jsut need to track down the right sensors now.
Old Sep 19, 2002 | 04:09 AM
The sensors seem like they would be the hard part, I would assume that the wiring is all the same behind it or that the harness is there. Where can we get the #'s for the sensors?
Old Sep 19, 2002 | 04:50 AM
T-bone's Avatar
Re: another problem with climate control
coming from an A/C unit in a 1990 Jimmy that blew warm air, I think this thing is great. My only complaint is that the 2nd fan speed is too much higher than the 1st.
Just adjust the outside temp
Old Sep 19, 2002 | 06:42 AM
Dany's Avatar
Maybe for the heat it works this way, but when you cooling the car down with A/C and you have Auto set it will stay on one mode all the time. At least mine does. Only fan speed will get adjusted.
Old Sep 19, 2002 | 07:35 AM
Dario's Avatar
try DaveB
Old Sep 19, 2002 | 08:42 AM
PrinzII's Avatar
OG and counting...
Another point about the switch
For the Meridian Package Maxes, the control for the heated mirrors is integrated into that switch.
In my '94 it was on the mirror control.
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
