Apexi Rev/Speed meter questions
Old Sep 28, 2002 | 10:05 AM
20006spd's Avatar
My bro installed a rev/speed meter on his 00 v6 5 speed camry, it was wired up so the factory 135mph speed limter should be cut, on the output menu under SLC 9speed limter cut) what speed does it have to be set at in order for the speed limter cut function to engage?
also the car came with 195/65/15 stock and now has 225/45/17,i did the math and the tire size percentage coems out to be 98%, i dialed that into the meter and now the speed reading on the rev/speed meter is a 2km different than the speedo reading? is this normal? is my ACTUAL speed the speed indicated byt he rsm (hence the Tire size CORRECTION funtion) or the speed indicate on my speedo??
thanks for the help guys, i cant find this info anywheres!
Old Sep 28, 2002 | 10:06 AM
Sprint's Avatar
so your 2000 maxima has a 6spd transmission?
Old Sep 28, 2002 | 12:25 PM
ToYLeT902's Avatar
JET Speed Lab
or he has 20006 different gears?
Old Sep 27, 2003 | 06:22 AM
Deac's Avatar
A different question
For those of you who know about wiring the Apexis... The S-AFC has a 2nd plug that you splice into that fits into the ECU but is it true the w/the APEXI-RSM, you just splice directly into the ECU wires? I've been looking for the plug for it that would plug into the ECU but after a bit of research on here, I read a couple of posts that implied that you should just splice directly into the ECU wires.... Just need verification. Any help would be great...
Deac
Old Sep 27, 2003 | 07:05 AM
UMD_MaxSE's Avatar
Got Bent?
Deac
the extra plug that goes from the ECU to the RSM plug isn't doing anything I think... As long as you got the wires matched up, you should be ok. You won't need any of the extra wires for the speed cut.... just cut the ECU speed sensor, wire it to the RSM and then wire the RSM speed sensor output back to the ECU.
As for Toyota's, they require the extra wiring for the speed cut... not sure on what settings are needed though...
Old Sep 27, 2003 | 08:06 AM
Deac's Avatar
I have the G-Sensor too, what to do with that? I blew my ECU last time when I tried to do this myself so I wanna make sure I have everything right now! Thanx for the help...
Deac
Old Sep 27, 2003 | 09:00 AM
UMD_MaxSE's Avatar
Got Bent?
Deac
G snesor plugs right into the RSM as far as I know... you just need to mount it somewhere... How did you blow the ECU? mixed up power and ground?
Old Sep 27, 2003 | 09:29 AM
Deac's Avatar
yeah got the power and ground backwards... I paid bigtime for that mistake. I wanna get it right this time.!
aw11power
Oct 10, 2021 04:57 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Socalstillen
Sep 26, 2015 12:01 PM
