57k and............
Old Sep 30, 2002 | 09:54 PM
Maximam's Avatar
57k and............
the car runs rough the first few seconds after an initial start up now like it is mis-firing, any ideas???
Old Sep 30, 2002 | 10:12 PM
BLaZin 2k MaX's Avatar
I got a 2k and about the same amount of miles and I have the same problem it seems that when I first turn on the car for at least 10-15 mins. Then everything is fine. anyone?
Old Oct 1, 2002 | 08:27 AM
Maximam's Avatar
ttt
Old Oct 1, 2002 | 08:48 AM
T-bone's Avatar
Re: 57k and............
spark plugs?
Old Oct 5, 2002 | 10:36 PM
Maximam's Avatar
Anyone??? Fuel pressure?
Old Oct 5, 2002 | 11:31 PM
Green 2kSE's Avatar
It could be the fact that you are in Colorado (high altitude), use of cheap gas or 87, your aftermarket intake may be confusing the ECU, who knows? You posted a similar complaint almost two years ago and didn't follow up on what happened when you tried 91 octane. In any case, try returning to your stock intake and use good gas for a while. Also, clean your throttle body if you haven't done it before. I have found that I get smooth starts when I wait a few seconds before I crank up the car. When you insert the key in the ignition, wait until you hear three beeps, that's usually enough time for the fuel pump to pressurize the line. Good luck!
Old Oct 6, 2002 | 01:11 AM
Maximam's Avatar
Damn good memory! I am in Vegas now and have just noticed the problem the last few weeks. Intake has been on for 6 mo. It is not slow to start but seems to misfire for a while, 15 seconds before clearing up.
Old Oct 6, 2002 | 06:27 PM
Maximam's Avatar
ttt
Old Oct 7, 2002 | 02:23 PM
young1976's Avatar
I get rattling sounds like tapping sounds when I first start when it's cold, after 20 secs, it all goes away. Clearances probably opened up a bit or could be synthetic or just because it's at 50g miles... if it goes away, I think it's ok. I dump some Techron in it once a while and if Chevron is available I get it. It helps with knocking too. I get knocking now too. Could be deposits or spark plugs or coils, I don't know and I seem to now care too much anymore. The car runs, out of warrenty, Nissan service sucks. oh well, I'm blabbing...
raffivegas
Aug 23, 2015 09:54 PM
81Max
Dec 10, 2008 06:57 AM
HitmanAngel2k3
Jul 22, 2005 10:15 AM
rob collins
Nov 16, 2004 09:05 AM
