Swapping Brake lines
Old Oct 1, 2002 | 05:59 AM
Dario's Avatar
hey guys this coming week im going to swap out my brake lines for some SS brake lines and was wondering how to do this mod. is it a PITA or is it pretty straight forward. and which lines do i have to switch out.
Old Oct 1, 2002 | 06:34 AM
karguy's Avatar
You'll be replacing the line that goes to the caliper. One for each wheel. There is a banjo fitting on the end that goes to the caliper and the other end is a threaded female flare nut. Very easy and straight forward. You have to pull 2 spring retaining clips from the line at each wheel. I used a ball peen hammer and channel locks to put them back on. You'll need brake bleeding tools and new brake fluid for when you bleed brakes. Should take about 90 minutes for everything! Very easy.
Old Oct 1, 2002 | 06:37 AM
Dario's Avatar
can i do just do the fronts for now or do i have to do the entire brake assembly??? u see what happened is that my brakes crapped out on me due to the pads breaking. so im getting brand new X-drilled rotors and brake pads for the fronts.
Old Oct 1, 2002 | 06:44 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Might as well do all 4 because you'll have to rebleed your brakes anyways (don't want to do it twice). The set comes with all 4 lines.
Old Oct 1, 2002 | 07:19 AM
karguy's Avatar
The brake bleeding procedure, right rear and left front, then left rear and right front will have you taking off rear wheels to bleed rears, while the rears are already off you may as well do the rear lines which you already have from the kit. 90 minutes time to do the work is for all 4 wheels. If you are going to do it, do it right, these are your brakes, they keep you away from other cars and telephone poles. There are 2 things I never cut corners on, tires and brakes!
Old Oct 1, 2002 | 09:46 AM
Dario's Avatar
yeah you all are right guys might as well do it now and save the trouble. thanks for all your help and hope to get my car back up and braking ASAP.
matts95max
Apr 23, 2025 10:44 AM
Mar 12, 2020 12:06 AM
t6378tp
Sep 29, 2018 04:27 PM
BkGreen97
Apr 2, 2016 05:47 AM
Johnny9595
Sep 16, 2015 07:20 PM
