SUbs in My 2001 GXE
SUbs in My 2001 GXE
I want to hook a system up to my 2001 Maxima GXE, actually a friend will be doing it for me. But i was wondering what i will need in order to wire them to my Non-Bose Stock Deck... I need a wiring diagram for the stock deck, and will there be any problems that i should be aware of or if there are any snags that people generally run into when hooking up a system...
Re: SUbs in My 2001 GXE
Originally posted by BLaZin 2k MaX
You might as well buy a new deck bc its gonna eventually burn out, we got some ****ty decks in our cars.
According to my Haynes manual (which does not show 00-01 models), this is the following for 95-99:
RF: + Brown, - Brown/White
LF: + Blue/White, - Blue/Yellow
RR: + Blue, - Pink
RF: + Red, - Green
You should also be able to test them once you get in there. The four wires are generally grouped together and you can test which one is which by taking a battery of any size and putting the + wire and - wire against the respective terminals. It will "pop" in phase with the correct speaker. This is also a great way to test whether or not you have your positives and negatives mixed up. Speakers will pop out when they are wired correctly. The will pop inward if they are out of phase.
Hopefully they kept the 4th and 5th gen colors the same.
Originally posted by PoweredbyNissan
why does he need a rca converter? I mean can't he just hook it up directly to his amp if he got the speaker level inputs on his amp? And people say the rca converter gives a better sound quality, is that really true or just marketing tricks?
Most amps have low level inputs, though (RCA inputs). You need to convert the hi level deck output (speaker leads) to low level (RCA amp leads). If you just crimp on RCA jacks to speaker wires that are coming from the deck and plug them in your amp, you will fry the bloody **** out of it.
Line level converters do not improve sound quality. They actually add distortion. But it is your only option if you have a deck without preamp outputs (ie: stock deck).
How does one remove the stock deck? Do we need special radio keys?
As for the wiring, I can't remember exactly. The easiest way would be to pull the lower portion of the rear door panels and peek inside. See what color wires are on the back of the speakers in the rear doors. From there, tap into the corresponding wires on the back of the head unit with the Line out converter. Don't cut em. Tap into them. Place the Line Out Converter (LOC) behind the head unit, connect your RCA's and connect a remote turn on lead to the fused side of the radio turn on lead. After you get everything wired, you should be set to put the amp and subs in the trunk.
Placing the LOC behind the head Unit allows you to easily remove it when you decide that you should have gone with an aftermarket head unit after all. Your RCAs will already be located behind the dash, hence a straight forward install at that time.
Got any questions, PM me.
I got the trim from the gear shift area out and the three things are the Hazard, Cigarette Lighter, and the Ashtray light. I could not remove the AC vents though, I tried pulling and it woudln't budge. I got flatheads and tried prying, it would move up a little bit, but would not come out! Why was I having so much trouble with it?
Originally posted by asu174
How would he hook it up directly to his amp? The only way he can do that is if he has hi level inputs on his amp.
I dont have a RCA converter and I hooked up an amp and two subs to my 2k2 maxima. All I did was that I tapped into some speaker wires and connect it to the amp, through the speaker level input or "hi level input" on the amp. It is kenwood KAC829, it has RCA inputs and those speaker level inputs. So, does my setup contradict your message? or is there something madly wrong with my setup? the amp hasn't been fried so far.
The A/C vents are the hardest to get out. Try wedging a flathead in between the radio and the vents. Then place your thumb inside the top slot on the vent and your four fingers on the top of the vents. Do a little wiggling and pulling. They're tricky. But they will come out. The thing is, there's at least one maybe two phillips head screws benind the vents that go to the top of the radio. Thats what you have to get to. If you can't get it,you might try searching for someone in your area who's done it before for a little extra help. Good Luck man. Glad I was able to help on the rest of the removal.
By the way, i work nights and that tends to be when I post. Sorry for the inconvienence (SP?).
Is this the write up / pictures you were looking for on stereo removal??
http://carstereohelp.com/stereoremovalNisMax3.htm
Here is the one on the wiring for the 2002 Max:
http://maxima.theowensfamily.com/audio.html
Hope this helps??
Hope this helps??
tarun900
19
12-20-2021 06:57 PM
AaronL
08-08-2020 10:31 AM
