Switch for Neons
Old Oct 7, 2002 | 07:13 AM
Bulldawg's Avatar
Switch for Neons
I wanted to install neons under the dash on my 2k2 6speed. I want them to be on a switch. What kind of switch would I need...please help...doing the install this afternoon
Old Oct 7, 2002 | 07:17 AM
asu174's Avatar
Clay Aiken has fancy genitals
Re: Switch for Neons
You have two options, but both will require the same switch. Just a two way switch will do (on/off). It is pretty simple: ground, + voltage, and lead from the neons.
But do you want ot be able to run them while the car is off? If so, you will need to wire it to the turn on (ignition). If not, just run it hot.
Old Oct 7, 2002 | 07:23 AM
acMAX's Avatar
go to radio shack or even home depot.
there are all sorts of switches you can choose from.
Old Oct 7, 2002 | 07:34 AM
silverkorn's Avatar
you will want a SPST (single pull single throw) rated for 12V or higher. when wiring make sure you have some kind of fuse hookup up, either off the neon tub wiring or on the actual switch. and then just do what asu174 said to.
Old Oct 7, 2002 | 10:33 AM
Kojiro_FtT's Avatar
When I did mine, I got a SPST On-Off-On. I wired it to ignition AND constant power. So they go on with the car, but I can turn them on when the car is off too. What I really wanted to do was wire them to the door's courtesy lights, so they go on when the door is opened, but I gave up when I couldn't find the wire inside the car .
Old Oct 7, 2002 | 10:35 AM
Playero's Avatar
Sanduguero
LIGHTER SWITCH!
Old Oct 7, 2002 | 01:52 PM
Bulldawg's Avatar
Thanks for the info
gavin68
Sep 18, 2021 12:36 PM
AaronL
Aug 8, 2020 10:31 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
lrb6805
Sep 24, 2015 05:03 PM
