cutting maxspeeds????
Old Oct 8, 2002 | 08:18 PM
BLaZin 2k MaX's Avatar
I just got my maxspeed springs in and i was wondering if anyone would recommend cutting one coil off of the springs to bring it alittle lower?????
Old Oct 8, 2002 | 08:22 PM
KLOOGY's Avatar
L33t BMW Drivah
All I can tell you is that they fit just right. I have no clearnace problems or rubbing. If you do take it off the front only . You would be riding a bit too low if you did front and rear. The front has 2 dead coils if i'm not mistakened....
Old Oct 8, 2002 | 08:59 PM
azhelipilot's Avatar
Got maxspeeds on mine also. And happy.Another inch and I'd have problems getting a jack under there.
Old Oct 8, 2002 | 10:47 PM
20th maxstyle's Avatar
Never cut springs. It will cause the spring to make a poping sound when you hit a bump. Cutting springs are a cheap way to drop your car. Don't be ghetto with a Max. It makes us all look bad.
Old Oct 9, 2002 | 12:12 AM
CO2kmax
I belive that springs are not intended to be cut. When u cut them they will bounce very bad. That is why u see all those ricer hondas bouncing so bad they can barley stay on the road. I could be wrong, please correct me if so. Please do not cut your springs.
Old Oct 9, 2002 | 12:34 AM
d_warner's Avatar
Old Timer
Nope. You're right. DO NOT CUT YOUR SPRINGS. Especially with progressive rate springs. If you cut one coil off, you'll be riding on the firm portion of the spring. That's why the Ricers bounce. Kiss your smooth rider byebye.
Old Oct 9, 2002 | 09:20 AM
PearlRalizinG2k's Avatar
i will cut mine !
a friend of mine got a 2000 SE and he cutted one coil of the front and it rides great!he rolling on 19's so it looks great and rides nice! so i guess one coil should be okai.
Old Oct 9, 2002 | 11:34 AM
regejaxx2kmax's Avatar
I know these springs aren't meant to be cut, but I had my installer cut the dead coils on my Maxspeeds. They were installed with the stock SE struts and haven't had any noises, bouncing or problems after 8-10k with them on. This will probably wear the shocks quicker, but those will be getting replaced next summer.
Old Oct 9, 2002 | 11:44 AM
2k2max's Avatar
Newbie question: what part is the dead coil? Is it a portion of the spring? If not, how much was cut off the front vs. the rear? thanks.
Old Oct 9, 2002 | 11:52 AM
2001SE's Avatar
Irvine with his 2000 GXE cut his front springs, his car looks really nice with that kinda drop(front lower then the back)
Old Oct 9, 2002 | 12:55 PM
Maxima Dan's Avatar
I just put MaxSpeed springs and Tokico struts on last week and I love the ride. I really don't remember seeing any dead coils on the fronts. I am probably wrong, though. Any chance someone could possibly explain what the dead coils are and how you can distinguish them from the live coils. If you look at a maxspeed front spring for a 5th. Gen it looks way shorter than the stock spring and all of the coils appear to have the same daimeter and spacing between them.
Old Oct 9, 2002 | 03:17 PM
Tai Mai Shu's Avatar
Here is the technical explaination for not cutting the coil.
If you cut the coil, you will increase the spring rate, so you will have a much harder ride. How hard?, It is impossible to say. The coil spring is nothing more than a torsion bar all coiled up. The spring rate is based on the entire length of the spring (like if you "unrolled" it). By shortening the length, you make it harder to "twist" the bar.
Old Oct 9, 2002 | 03:24 PM
Well what about springs clamps?
Old Oct 9, 2002 | 03:30 PM
Ghetto
Old Oct 9, 2002 | 03:59 PM
Hey 2k2max, I had one coil on each spring cut off and the drop was even for some odd reason. My understanding of the dead coils are the coils on the top of the spring in which the distance between coils decreases. Maxima Dan said he couldn't see and dead coils on the front springs, and he might be right. I went to my garage to see the portion that was torched off and it doesn't look like a dead coil.
2k2max, if you want to see the results, you can check my homepage, but if you want to see the portions that were cut off, I can post those also.
Old Oct 9, 2002 | 07:48 PM
JoesMAX's Avatar
anthony (ny96max) cut his H&R's and the ride is the same as it was before.. when i get kyb agx's i want to have my front springs cut to even the drop out a little bit. the front is like a 3 finger and the rear is 2, i was it to be 2 all around. sometimes it looks like i have too much weight in my trunk
not to mention if youre on a hill with the front facing up, it makes it even worse
Old Oct 9, 2002 | 09:40 PM
KLOOGY's Avatar
L33t BMW Drivah
Im not some moron firing off BS. I have spoken to a lot of Max owners. Hoon, " IRVINE78 " , did it on his Max and got great results. His Max looks PHAT ! I wont do it, because I want to go with 255's all around, and I usually ride with 4-5 ***** in my whip... I need to clear those bumps...
Look ay Irvine78's car.. thats the way a lowered Max should sit !
Old Oct 9, 2002 | 10:49 PM
Step2kMax's Avatar
almost 2 in the morning, not feeling good(some 24hr bug) and kloogy.... you gave me the laugh i needed.
Thanks man!
Old Oct 9, 2002 | 11:07 PM
slickrick's Avatar
the reason i like having 4 people in my car is to give my stock ride a lowered look, now thats ghetto.
Old Oct 10, 2002 | 06:37 AM
buzek's Avatar
I would like to cut my front H&R's as well. How much? how do you measure? Hight or linear? From which end? top or bottom. I think they can be compressed and cut without removing from the car. I would just use a die grinder--air powered of course. That way could just take a little at a time until just right.
Old Oct 10, 2002 | 08:07 AM
JoesMAX's Avatar
im not sure you would have to ask him... he had all 4 cut though, and his wheel gap is an even 2 finger all around.. and i think his were just compressed and cut also. i wouldnt cut my fronts if they made springs with an even wheel well gap, rather than just an even drop front and back
Old Oct 10, 2002 | 09:15 AM
buzek's Avatar
I see what you mean but I don't want any more drop in the rear..less risk of rubbing with people in the car. But I would like the front lower.
James92SE
142
Jan 2, 2024 09:23 AM
magiconthetire
Oct 26, 2015 09:03 PM
RealityCheck
Oct 2, 2015 06:34 PM
Taino14
Sep 24, 2015 02:51 PM
