Audio Question- Amp wiring
Old Oct 11, 2002 | 10:44 AM
asu174's Avatar
Clay Aiken has fancy genitals
With the JL Audio 500/1 amp (mono), if I want to run 2 12"s, do I need DVC or SVC? I used to be a certified installer, but we didn't have mono amps back then and I have been out of the game for a while. I can't remember everything either......
Anyhow, the amp is 1.5 ohm stable. I am guessing I need 2 SVC subs and I need to run them in parallel? Or am I way off on that?
Old Oct 11, 2002 | 11:09 AM
silverkorn's Avatar
Re: Audio Question- Amp wiring
if your going for sound quality i would get either two mono amps or one stereo amp. Then you could have DVC subs in stereo that gives you a great all round sounding system. and still have the power to put out some serious SPL.
Old Oct 11, 2002 | 11:14 AM
Kojiro_FtT's Avatar
To get the most power out of your amp, you want to give it a 2 ohm (or 1.5 ohm since it can go there) load. So do the math and figure what 12" combination will give you 2 ohm.
a.) If you get two 4 ohm SVC subs, then you can run in parallel.
b.) Or, you could get two DVC dual 2 ohm woofers, run in parallel to each sub but each voice coil in series, so 2+2=4 but in parallel with another 4 is 2 ohm.
c.) Or you could even do 3 SVC 6 ohm subs in parallel, but then each sub is getting less power.
Anyways, do a or b. b) is the easiest. Get two JL 12w3v2 dual 2 ohm subs.
For info on DVC installs, try JL Audio's DVC faq.
Old Oct 11, 2002 | 12:14 PM
releasedtruth's Avatar
rilla dope
Re: Re: Audio Question- Amp wiring
I'm a fan of the stereo myself too. I just rewired mine for less power to a stereo load on a 2 channel amp rather than the 1000x1 I was getting I now get abou 400x2 and it's real sweet
As far as wiring, 2 12" DVC 4s would give you 2 2 ohm loads for stereo if you went that route or boviously 2 SVC 2ohmers
Old Oct 11, 2002 | 12:23 PM
slickrick's Avatar
jl audio amps are stable from 1.5-4ohms and put out the same power at each ohm. thats for better system flexibility. so no more power at lets say 2 ohms than at 4 ohms on jl amps.
Old Oct 11, 2002 | 12:59 PM
Kojiro_FtT's Avatar
Ahhhh.. I see! I totally didn't know that. Well, in that case you can use whatever frigging subs you want man.
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
