alignment question
Old Oct 17, 2002 | 08:22 PM
MAXRAY's Avatar
alignment question
i've search several posts and have seen different responses. i'm planning to finally put h&r springs on next week. i know i should wait about a week before an alignment. some have posted that i only need front end while others have gotten 4 wheel alignment done. so, what's the real story?
Old Oct 17, 2002 | 08:39 PM
Y2KSESteve's Avatar
Re: alignment question
I personally would align right away...
Old Oct 18, 2002 | 12:29 AM
serin's Avatar
with the beam in the rear, i was told the rear couldn't be aligned. besides, don't they all cost the same anyway?
Old Oct 18, 2002 | 02:59 AM
Nismo's Avatar
some machines require them to hook up the lasers to all 4 wheels to calerbrate them for the allignment so thats why they call it a 4 wheel allignment. they work on the car as if it was a 4-wheel allignment but they just dont do any adjustments to the rear wheels because its not possible. If they were to use bubble guages then thats a different story.
Also, I dont know if its wise to allign it right after the install since it takes time for the springs to settle. If you allign it when they are not settled, that means when they settle, it may be off again.
Old Oct 18, 2002 | 03:47 AM
Norm Peterson's Avatar
If you wait for the car to settle, which might take 1000 miles or more, your tires can start to develop a bad wear pattern. So you should align right after the install and then check it after a while or if (when) the car has settled measurably.
Norm
Old Oct 18, 2002 | 05:49 AM
Virus's Avatar
You should definately do it right away. Every place you go to have your alignment done will give you a minimum of 6 months or 12k mile warranty. Take it back after they settle and get it done again for free.
Old Oct 18, 2002 | 08:33 AM
ajahearn's Avatar
alignment
Slightly more than a month ago my neighbor installed Eibach springs in my car. I took it to a local place and had the alignment done immediately. The car was driveable but I didn't go very fast nor very far. The alignment absolutely needed to be done (based on the number report they showed me). I just recently took it back to have them check (it's been a little more than a month). They checked the alignment and it had changed only slightly but not enough to warrant any work. So it would seem advisable to do the alignment immediately, and if it makes you feel better, to follow up later.
Old Oct 19, 2002 | 11:07 AM
MAXRAY's Avatar
bump
Old Oct 19, 2002 | 11:09 AM
ABS's Avatar
ABS
Also, from what I've read on other posts (you'll have to "search" for it), the handling/tracking of the car may be improved by setting the toe-in to the manufacturer's maximum limit. You should confirm this though . . .
trsandrew
Apr 8, 2016 06:45 PM
Unclejunebug
Apr 2, 2016 05:42 AM
doctorpullit
Mar 29, 2016 11:08 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Socalstillen
Sep 26, 2015 12:01 PM
