2k1 Dyno with Budget Y-Pipe
Re: Re: Re: Re: Re: Re: Sounds good...
Originally posted by 2K2DEMAX
Naturally happened. Now exposed is the metal and all the piping is stainless. That's why I was thinking that they only painted it for aesthetic purposes.
Do you have any pictures?I can't believe that's normal, but maybe it is.
Re: Re: Re: Re: Re: Re: Re: Sounds good...
Punch84 : Yes, the F-pipe is the same thing.
The Y part of the pipe
Side shot
Pipe between flex and main cat
http://images.cardomain.com/installs...32_50_full.jpg
Originally posted by Punch84
One more question, sorry. Is this compatible with my 2000 Fed spec Max? Thanks.
Dave.
Dave.
Re: Re: Re: Re: Re: Re: Re: Re: Sounds good...
Ok man, here are some pics showing the pipe on the car. Notice the paint is all gone except for the little piece between the flex and the main cat. Also notice that stainless steel is used on all parts of the pipe.
http://images.cardomain.com/installs...32_49_full.jpg[/img]
Side shot
http://images.cardomain.com/installs...32_51_full.jpg[/img]
http://images.cardomain.com/installs...32_50_full.jpg[/url]
Side shot
Originally posted by BlackMax2k1
How loud would it be with an aftermarket muffler? Too loud?
Originally posted by Max_Gator
Not flaming, but given that I'm not sure that your comparison dyno is of much value.
If anything, you should just use the numbers above which would show a 23 hp gain and a 1 hp TQ gain.
From what I've seen, ypipes give limited TQ gain but decent HP gain. So, 1 ftlb of tq is consistent. However, I would be really surprised if you got 23hp.
But it you can really show that hp gain, I might go to the Budget!
the graph shows the biggest increases after the VI opens; however, 3rd gear right now is definitely stronger in terms of TQ than what the graph indicates.
i'll be getting the Budget B-pipe sometime soon and will have a dyno of that too (this time one in 2nd gear and one in 3rd gear)
From my experience, having an aftermarket straight-through muffler (with stock b-pipe) in series with a y-pipe will not be quiet. However, it is not obnoxiously loud either. Replace that stock b with a larger diameter pipe along with the above configuration and it gets very loud. Right now I have the y + 2.5" mandrel bent b with a resonator + stock muffler and it is perfect.
Help me out.
I have a 2KSE and was going to add a Y pipe and B pipe with a resonator. I am concerned that there will be too much of a noise increase. What is your experience with your set up? My wife and kids will notice if there is too much of a difference and I want to keep any noise increase to a minimum as I often cruise at 65-80 mph.
What percent increase in noise inside the car, over stock, is there at idle?
At WOT?
At 70 MPH?
Or, when on the tach does the noise become more noticeable?
Thanks,
Jack
At I
Originally posted by jarturo
DEMAX,
Help me out.
At WOT?
At 70 MPH?
Thanks,
Jack
At I
DEMAX,
Help me out.
At WOT?
At 70 MPH?
Thanks,
Jack
At I
startup - a little growl
Idle - quiet
WOT - hard to tell, my intake roars above the exhaust sound.
70 mph - quiet (like stock)
Let me put it this way, if you don't have an intake, they really won't know the difference. In fact, I would say that when you drive with the windows up and the a/c on it is identical to stock.
Really, I am pleased with this setup. As long as you keep your stock muffler, you should be fine.
Now, remember that this stuff is very subjective so the terms "quiet" and "growl" are based on my tolerance levels. (my disclaimer)
Originally posted by jjs
I'm all for saving money, but with a price that low, how much farther down do you think a GD will get?
Originally posted by T-bone
I agree that the price is low, but we obviously have a lot of interested people. Let's make them an offer they can't refuse!
"Hi my manufacturing department is on holidays until Thurs. I will forward your e-mail and they will respond on Friday
Jody
Budget Exhaust"
so I guess we'll have to wait a couple days. If a GD is on, lemme know cuz I'm in.
Originally posted by HulaMAX
I emailed Budget (Jeff) yesterday with questions and got this reply:
Jody
Budget Exhaust"
Jody
Budget Exhaust"
Well lets setup a GD. I bet we can get 10 people easy. Budget will not be able to resist our American money
Jody
Budget Exhaust"
Jody
Budget Exhaust"
2K2DEMAX
I have an intake so it's a little difficult to discern the exhaust note from the intake roar. However, as best I can differentiate them, here is what my observations are:
Idle - quiet
Idle - quiet
Did you connect the B-pipe to the STOCK rear section(pipe/flange over axle) or did you weld it straight to the muffler? If straight to the muffler, did you "open up" the hole entering the muffler?
Re: 2K2DEMAX
How did you connect the 2.5" b-pipe to the muffler?
Re: Re: 2K2DEMAX
Connected it to the unaltered stock rear section. I did it that way so I could easily interchange between the OEM rear section (daily driving) and my HKS rear section (when I go to the track).
You've been VERY helpful.
Thanks,
Alex
Those Canadians and their holidays....
one reason you can use pertaining to setting up a GD is that the price we pay ($250CAN) when we go into Budget includes installation so... just an idea
Originally posted by MajesticBlueNTO
what you talking bout willis? i don't have a holiday
Budget Y-pipes and Hockey...2 great things from Canada.
I know. According to my "at-a-glance" calender, Canada celebrated Thanksgiving on the 14th. Thanks for the info on the GD.
Good luck on the GD
Originally posted by Ironlord
Awww heck, i'd get in on a GD for this, i'm tired of waiting for warpspeed and their 6 months of next week....
and besides, i need more power now that i have my sticky rubber...
I have to do some work
The one I got will not work on Fed spec cars. What you should do is give Jeff at budget a call. I think I saw on the Canadian forum that Jeff made a Fed spec Y pipe for a guy with a 2k. Calling Jeff is your best bet.
That was me. He made one specifically for my 2000 Fed Spec.
Just make sure you tell him exactly what you need. He made two when I was there on site so he could make others without the need to have another 2000 Fed Spec. If he's still confused, tell him you need the same one as the guy with the Black Maxima who needed a custom pipe built and he made 2 of them. Also tell him I was the guy with the CAI (he was interested to see the Place Racing one because Jeff was thinking of making his own using the same design as Place Racing instead of the Injen design). Good luck!
By the way, Jody knows about maxima.org and already has a "special" with us members. So the 160 US shipped is already discounted for org members. Now that discount is for individuals. You might be able to get a lower price with 10+ people. (Just giving you guys the context of the price).
Good luck!
Good luck!
so can someone start a GD or "gauging interest" thread.
Something's strange with your original numbers. No way they should be that low - especially the torque. Your torque numbers are 40ftlbs below my stock numbers. You hp numbers are low too - at 3500 rpm I've got 125 hp and you've got 75.
Take a look at my stock plot.
http://web.tampabay.rr.com/maxgator/...revsafter3.bmp
I'm guessing you have an auto - I have a 5 spd - but still those seem to be very low.
