Replacing stock rims....help
Old Oct 21, 2002 | 10:09 PM
davsan's Avatar
I plan on replacing my stock rims. I have a 2002 Grey Lustre color SE model.
I want to go with an 18", but need to know if there is anything I should consider before moving from the stock rim???
Also, what are the most attractive rims for this model? I want sporty, but not too flashy. Thanks
Old Oct 22, 2002 | 05:52 AM
njmaxseltd's Avatar
Re: Replacing stock rims....help
Consider not going to an 18" rim. They ride pretty hard because there's not much rubber left to cusion your car's suspension from the road.
Just my .02
Old Oct 22, 2002 | 06:26 AM
2Maxed-out4u's Avatar
Re: Re: Replacing stock rims....help
Just my .02
18's aren't that bad at all, cause I have had them for almost a year. Of course the ride will change a little, but it's not that bad. Plus the new look to your car will make you forget about the change.
Old Oct 22, 2002 | 07:53 AM
Galo's Avatar
Maxima Pilot
Finally...a few other folks to ADMIT that
changing to anything larger than 17" will create some sort of negative impact to the ride quality!
Galo the official 19" wheel hater
Old Oct 22, 2002 | 09:10 AM
slickrick's Avatar
2maxed-out, do u live in gainesville? ive seen a car just like that riding around UF's campus. if it is, ive seen you parked at the yulee parking area, thats where i have to park sometimes.
Old Oct 22, 2002 | 09:23 AM
PoweredbyNissan
Re: Re: Re: Replacing stock rims....help
Am I correct to assume that you have factory struts and springs?
Old Oct 22, 2002 | 10:10 AM
cwally's Avatar
I think these wheels would look tight as **** on the max. Nice but not too flashy. http://www.tirerack.com/wheels/image..._ssl_ci3_l.jpg
The ride isnt that bad on 18"s. I've had them for quite a while now, and I actually upgraded to 19"s. Its not as bad as they say. Here is a pic of these wheels on an Audi.
http://www.tirerack.com/wheels/image...otionssl_2.jpg
jskirwin
Jun 8, 2016 08:49 AM
melteye
May 16, 2016 12:02 AM
Maxilano
Aug 31, 2015 07:33 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
YourLocalAsian
Aug 17, 2015 02:33 PM
