attn: adiophiles: Just wanna add a small sub...
Old Oct 22, 2002 | 07:42 AM
Y2KSilvahSE's Avatar
Fellow adiophiles, my max has the midrange system available when the 2k max first came out. CD, tape (used once lol) and 5 speakers, fronts up in dash, and rears in back seat near your feet. All totally factory. The sound is not bad, but lacks just a little more in the low freq range. I have a killer home system, so I didnt need one in the car, and didnt have the $ at the time I bought the max.
1. Is it real tough just to add a small (or the smallest available) powered sub in the trunk, or maybe the rear lid? (that has a place to add another speaker, probably the one that comes with the optional bose)
I'd imagine wiring power and signal wires will be tough to do correctly.
2. Will this powered sub have alot of noise at lower volumes?
3. Would a local car audio joint cost a ton of bucks to just add a sub? (if its indeed possible)
Thanks guys in advance!!
Gary
Old Oct 22, 2002 | 07:50 AM
Kojiro_FtT's Avatar
Re: attn: adiophiles: Just wanna add a small sub...
Gary
Lot's of options there. Anything from a $40 8" powered sub from Wal-Mart to a $1000 custom box system. Depends on what you want. If you're keeping the stock setup, the easiest way would be to tap into one of the rear speakers and run that to the line-level input of an amp.
I'd recommend you go to your local Best Buy/Curcuit City type place and have them install a 10" woofer in one of those Q-sound ported boxes with a modest size amp, like 200 RMS. Anything more would be overkill with the stock system. If I'm not mistaken, those places usually have low install costs.
Old Oct 22, 2002 | 07:51 AM
MaxSE2k's Avatar
Look around for an Infinity Basslink ($200 online). A lot of members are adding this to their system because it makes a pretty good level of sound, weighs 14lbs, and comes with a remote level control. Do a search, it's pretty easy to install (very easy actually). Do it yourself and save on the 2 hours of labor the shop would charge.
Old Oct 22, 2002 | 07:56 AM
Kojiro_FtT's Avatar
There you go, that's perfect for you.
Old Oct 22, 2002 | 08:00 AM
soundmike's Avatar
Very sound, Mike
Another vote for the Basslink
Old Oct 22, 2002 | 02:47 PM
Thanks Kojiro & MaxSE2k. Basslink it is! With the shape my back is in, I'll slide them a c note (or whatever) and avoid the pain.
Thanks again boys...happy listening!
I'll report back when the mod is done.
Old Oct 22, 2002 | 02:57 PM
MaxSE2k's Avatar
Fill up your gas tank, pick up some brew, and we can take an afternoon and do it. Oh - 1 catch, help me locate some old girlie girls in Leominster that I met some time ago I'm like 2 hrs from ya, but what the hell, nothing like some foliage peeping.
Old Oct 22, 2002 | 07:19 PM
AE Majestic Blu's Avatar
I bought a basslink at The Wiz it is a store on Long Island that just closed it was 30% off so i got it for $200. It was sooo easy to install. The sound is amazing except for the rattle from the trunk which is unavoidable. Otherwise its amazing. The hardest part is figuring out which speaker wires are which in the back.
Old Oct 22, 2002 | 09:11 PM
MAXRAY's Avatar
doing a search, i have found multiple different methods of installing the basslink. what's the simpliest way? i'm thinking of tapping into the power and speaker wires before going into the factory "amp" in the trunk. will that work instead of drilling through the fire wall and directly powering to the battery and tapping into the door speakers?
Old Oct 22, 2002 | 10:37 PM
BlackMax2k1's Avatar
Where can you get it online for $200?
Old Oct 23, 2002 | 05:04 AM
MaxSE2k's Avatar
http://www.carstereo2000.com comes w/ remote bass control for about $200
Old Oct 23, 2002 | 05:28 AM
Any place else besides that ghetto website?
Old Oct 23, 2002 | 05:29 AM
MaxSE2k's Avatar
Look around - ebay maybe... they're usually the ones on ebay that sell the most. There's others out there. The search function works nicely too.
Old Oct 23, 2002 | 07:38 AM
Sounds good basically, but my fiance/ wont like the girlie-girl part
Plus...the weather lately stinks...snowin here today and no garage available for me...I'm in a condo.
Old Oct 23, 2002 | 07:42 AM
exunaja's Avatar
I am kind of wandering to, I know that a few person in this board has replace their stock bose with a better sub.
but I am not sure either how to tap the wire for power and speaker input before the stock amp or somewhere else
MaxSE2k's Avatar
Girlies for me! I'm just trying to find some old friends that I've lost touch with...
Old Oct 23, 2002 | 07:45 AM
Someone correct me if I am wrong...but It might not matter which one of the speaker wires you use for the signal wire going to the sub. Then all you need is the power line.
I am not sure about that though...
Old Oct 23, 2002 | 07:47 AM
MaxSE2k's Avatar
Run new power from the battery... the install kit comes with wires to tap into all 8 speaker wires, this way the sub won't fade out from front/rear. The easiest place to tap in is behind the head unit, and just run everything back together. You don't need a remote turn on because the Basslink detects signal from the speaker inputs and automatically turns itself on.
bigdogsteve
Jan 31, 2018 04:18 PM
Fbana41
Aug 29, 2016 12:18 PM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
