2k2 Maxima Rental going to the track this Friday! :P
Old Nov 5, 2002 | 09:41 AM
  #121
Acura2001CL-S's Avatar
Originally posted by SteVTEC
[B][u] CL-S is 0wN3d beyond 110 and you know it, Russ. Several guys here with 2k2 autos have ran CL-S's on the highway. It was pretty close below 110, but after that the Max guys just walked away. They kept on hauling in 3rd whereas the CL-S has to go all the way up to its tall OD 4th.
Nothing Comptech or OBX headers won't fix.
Old Nov 5, 2002 | 10:02 AM
  #122
Dany's Avatar
Yeah, I hope headers do help.
I ran my friend's stock TL-S and it wasn't even close. I really thought that his VTEC will give me a better run especially when we ran on the highway.
Old Nov 5, 2002 | 11:24 AM
  #123
The TL-S is slower than the CL-S didn't you know that.
Old Nov 5, 2002 | 12:06 PM
  #124
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
By how much TYPICALLY?
I've seen magazines go both ways, but the CL-S is lighter therefore SHOULD be faster, right?
Old Nov 5, 2002 | 12:10 PM
  #125
Re: ...
From the times they post on both forums the CL-S has the faster times...not including the 6sp CL-S of course.
Old Nov 5, 2002 | 12:29 PM
  #126
IceY2K1's Avatar
Re: Re: ...
Ok, I figured that, but HOW MUCH faster TYPICALLY?
Old Nov 5, 2002 | 01:18 PM
  #127
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
Re: Re: ...
That's just because the CL-S guys mod a lot more and go to the track a lot more, whereas the TL-S guys, in general, seem to be much less interested in modding, and racing whether it be street or track.
The two cars are IDENTICAL as far as drivetrain goes, and the TL-S is only 50 lb more than a CL-S. When you're talking about 3500+ lb cars, 50 lb isn't going to make any sort of measureable difference.
And yes, 6spd is a different story
Old Nov 5, 2002 | 06:32 PM
  #128
Virus's Avatar
You guys are hilarious. Your talking about miniscule 10th's of a 2nd. Anyone could win at anytime.
Old Feb 23, 2003 | 05:25 AM
  #129
Chinkzilla's Avatar
Then what's up with the NissanPerformanceMag dyno?
Hi! That's my car's dyno btw.
Sorry to revive a dead thread but there was an interesting technical discussion going on before it became an nissan vs. acura thread.
That dyno was taken on stillen day while my car was still bone stock. The stillen guys saw fit to let my car sit running in the hot sun for a good 20 minutes before they put it on the dyno. Not only that but the guy claimed that I didn't need a fan in front of my intake because I wasn't "boosted". Yeah right.
Either way it's a perfectly average dyno for a stock 2k2 max. Since it was printed 'portrait' style on 8.5X11 inch paper, the graph is skewed differently than most that you see. Therefore any variations on the horizontal axis seem more dramatic.
True the power does start to drop off around 6000 rpm, however still makes usable power till redline. This combined with tachometer innacuracy, means that shifting at redline (6200 rpm in reality) will land you right in the meaty portion of the powerband at 5200-5300 rpm through the next gear. For an auto you may even want to shift higher because the gear ratios are longer thus rpms drop more between gears.
There is real life evidence for this since while on the track, I ran my best time of 14.4 when shifting PAST redline. On runs where I shifted earlier, I was hardly able to break into the 14's.
By no means is the 2k2+ max a top end screamer like a vtec acura, but to make best use of your (relatively flat) peak powerband, you need to shift late-ish. (I feel like my car gained a sh!*load of topend when I put on my intake, so that may have been a limiting factor.)
SteVTEC: no offense and I'm sure you already know this, but it's quite normal for torque to begin to drop off at 4800rpm and drop off completely 5000rpm+ since horsepower is calculated hp=(ft.lbf*5252)/rpm.. Which is why all proper dyno graphs should cross at around 5000rpm.
Old Feb 23, 2003 | 03:38 PM
  #130
max...to the ma's Avatar
Originally posted by Wasim521
Dammit...I bought a used car that used to be a rental...I'm getting scared now reading all this Russ!
dude, no offense, but thats not a very smart move
Team STILLEN
Aug 10, 2015 04:29 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
