engine coolant
Old Nov 5, 2002 | 11:26 AM
mikemmcd's Avatar
engine coolant
I have a 02 Max GLE and I was checking the
fluids this morning and I noticed that the engine
coolant was quite low. It was still above the low
mark. I have never had this happen. I do not see
any leaks. Is it possible that the coolant is
in the radiator? I don't want to put more coolant in and overfill it. I has been quite cold here in NY and maybe that has something to do with it.
Everything else is normal.
Old Nov 5, 2002 | 11:35 AM
saxdogg's Avatar
If it is above the low marking on the bottle, then it is normal (for a cold engine). It expands from the radiator to the bottle when warmed up. Level should then be at the HOT line.
arff
Old Nov 5, 2002 | 11:36 AM
njmaxseltd's Avatar
Re: engine coolant
It was still above the low mark.
It's a closed system. As long as your above the low mark [b]cold[/c] when your engine is cold, your system is full. If you check it again when the engine is hot, you'll notice it's come up some.
Old Nov 5, 2002 | 11:42 AM
mikemmcd's Avatar
yes, it is above the low mark.
I figured thats what it was but I guess I never
really checked it before was the engine was cold
and would not have noticed
MR2 T'd
Jul 9, 2021 05:06 AM
captchaos
Mar 15, 2016 12:18 PM
bumpypickle
Sep 20, 2015 08:22 AM
97_GXE
20
Sep 17, 2015 08:12 PM
Hdnseek
Sep 9, 2015 05:55 AM
