JW Pop Charger
Old Nov 10, 2002 | 04:28 PM
NemaMax's Avatar
JW Pop Charger
5 months ago..i got my maxima a Jim Wolf Pop-charger from courtesy nissan...having almost no knowledge about cars and no fear...i carefully installed it myself..
and here it goes...so many mechanical problems started to occur
1. engine shaked like crazy..not all the time..but very often
2. check engine sign came on( i disregarded it becuz this guy from a body shop told me the sensor is reacting to increased air to the engine.)
3. too much of a shaking..so i put my stock air-filter back in
4. car keeps shaking afterword..i take it to a dealer and they said it was probably engine mount...but later found out that it was spark plugs that went out...
5. replaced sparkplugs..and my car is finally ok..
anyone with JW pop charger plz tell me what went wrong with my car?
cuz i wanna make use of my pop charger that cost me almost 120 dollars...plz....thanks
Old Nov 10, 2002 | 05:42 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
1. the engine should not be shaking, sounds like an idling problem. when did the shaking occur? under acceleration or idling?
2. the check engine light should not come on, the ecu does take time to adjust to more air coming but it should not throw a ses light unless something went wrong with the install.
3. thats what i would have done.
4. odd but im sure its possible
5. at least the shaking is gone.
now did you have the code pulled to see what the error code is? what year and how many miles are on the max when the check engine light went off?
Old Nov 10, 2002 | 10:02 PM
NemaMax's Avatar
Thanks for the reply..
it's a 2000 Maxima GXE
about 50k miles on it...
i really wanna put that pop charger back in to ggain more horse..
but i wanna be sure how to..cuz replacing spark plugs is expensive..
thanks
Old Nov 11, 2002 | 06:10 AM
sloppymax's Avatar
well, my take on it is that the plugs had 50k on them. the platnium plugs are supposed to be good for 100k but theres no way i would leave them in there that long. im taking mine out at 30k to check them and then replace them no matter what at 50k or so. a plug or more could have easily fouled in 50k but putting on a pop charger might have just occured around the same time. i doubt if the filter caused the plug to foul, at least ive never heard of that one. i would put it back on but make sure you remove the negative terminal of the battery so you are less likely to throw a check engine light.
Old Nov 11, 2002 | 12:03 PM
NemaMax's Avatar
thanks again...by the way
do you happen to know how?
cuz the instruction site tells me i need a slight modification for installing pop charger..thanks
Old Nov 11, 2002 | 07:57 PM
sloppymax's Avatar
im not sure what the slight modification might be. it might be referring to removing the stock airbox or it could be the relocation of the air temp sensor. check this out and see it is similar to the instructions you received.
Mahmuth
Aug 16, 2024 08:23 PM
litch
123
Jan 4, 2024 07:01 PM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
trungg86
Sep 4, 2015 04:58 AM
