Koni's on 5th generation
Old Nov 18, 2002 | 09:03 PM
JK20th's Avatar
I've seen several 5th generation maximas equipped with koni shocks manufactured for 4th generation veh's. Are the shock & strut assemblies the same on the 4th's and 5th's? Are there any mods required to put Koni's on my '01 20th Anniv Max? I'm looking to put a set of H & R Springs and upgraded shocks, and have read many good and many bad reviews about Tokico and KYB shocks for 5th gengerations. Would like to put the Koni's on but they told me they won't have an application for Gen 5 until early next year. Any opinions/experiences would be greatly appreciated. Thanks JK
Email me here:
Old Nov 18, 2002 | 09:42 PM
[maxi-overdose]'s Avatar
Re: Koni's on 5th generation
Email me here:
check out maximadriver.com for installation guide. those konis are the same for 4th and 5th gen and it requires to cut ur front struts open, drain the fluid, and re-inesrt the koni shock inserts. check out my homepage too if u like.
someone just got a reply back from koni-usa and the rep stated that the 5th gen shocks will be here after Christmas.
Old Nov 19, 2002 | 08:49 AM
JK20th's Avatar
Re: Re: Koni's on 5th generation
Thanks for info and link. If I don't want to cut my original struts, what's the consensus on Tokicos and KYB's?
Old Nov 19, 2002 | 09:00 AM
JK20th's Avatar
Thanks for info and link. If I don't want to cut my original struts, what's the consensus on Tokicos and KYB's? How long did the install of the Koni fronts take?
Old Nov 19, 2002 | 12:10 PM
it took my installer 2 hours to do the front struts (unintall, cut, install) Since u r going to go with H&R....I think it is ok to go with tokicos because HR is not that stiff. I would recommanded KYB and cattmanperformance.com has them modified for 5th gen. I choose Koni because KYB had problems with eibach on rear struts.
In addition, KYB rear strut stiffness is on-car adjustable, Konis are not....
Old Nov 19, 2002 | 12:57 PM
JK20th's Avatar
Thanks again.
James92SE
142
Jan 2, 2024 09:23 AM
MAXSE5SPD
Sep 17, 2022 04:00 AM
Mar 12, 2020 12:06 AM
mkaresh
Mar 12, 2018 06:48 PM
AcuraLegend
Oct 17, 2016 08:47 PM
