Koni Question
Old Nov 22, 2002 | 11:26 AM
2k2nyc's Avatar
Koni Question
I'm thinking of getting the AGX's in the front and Konis in the rear. Do the rear 4th gen Konis have to be modified as well?
Old Nov 22, 2002 | 12:14 PM
Galo's Avatar
Maxima Pilot
No.
Old Nov 22, 2002 | 12:44 PM
2k2nyc's Avatar
Re: No.
Originally posted by Galo
Thanx!
Old Nov 22, 2002 | 05:00 PM
jykishan's Avatar
Re: Koni Question
why you goin this route? cuz the 4th gen agx rear shocks fit unmodified on 5th gens as well.
Old Nov 22, 2002 | 05:16 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Re: Koni Question
Are you sure you don't mean Konis in Front and 4th gen AGXs in the REAR?
That might be the IDEAL setup, but nobody has tried it.
What a pair of Koni shocks and AGX struts cost?
Old Nov 22, 2002 | 06:24 PM
[maxi-overdose]'s Avatar
Re: Koni Question
ah...mixing struts...someone did it before with AGX rear and Tokicos front. I heard the ride was funny b/c from is too stiff and rear is too soft. But with adjustable Koni and AGX....u might figure out an ideal setting for you. Adjusting rear Koni will no be easy. You have to take it off, turn it and put it back on. then test drive.
let us know how it goes
Old Nov 23, 2002 | 08:07 AM
Galo's Avatar
Maxima Pilot
Koni fronts require the same upper shock
mounting plate replacement the AGXs need because they are engineered for the Gen4s; they are a direct fit on the rear because the Gen4 rears are exactly the same as the Gen5 rears.
Now, that said it begs the question: if you are thinking of going the AGX route in the front -hence you'll need to replace the upper shock mounting plate anyway- why not go Konis all the way around? In other words, why do u wanna mix instead of match?
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
