HELP!! Changing Brake Pads
Old Nov 25, 2002 | 11:56 AM
BluLite's Avatar
I am changing the rear brake pads, I got the driver side ones to go on. But the passenger side piston wont budge. I opened up the bleeder plug but its still hard. I need help What can I do.
Old Nov 25, 2002 | 12:07 PM
MaxRPM's Avatar
Re: HELP!! Changing Brake Pads
You can't push them in. Take some needle nose pliers and place the tips in the notches in the piston. Turn the piston until it goes far enough back in for you to place the pad over the rotor. Don't forget to pupmp your brakes before you move the car.
Old Nov 25, 2002 | 01:09 PM
BluLite's Avatar
Re: Re: HELP!! Changing Brake Pads
I'm turning the piston (clockwise) and it is still not going back in. When I turn it (counter clockwise) I feel a notch. What can I do now? So screwed. Thanks in advance.
Old Nov 25, 2002 | 02:33 PM
BluLite's Avatar
ok i got the piston to go back down and put everything back together. Now i dont have any brake pressure. How do i get it back? And my hand brake takes like 40 clicks to get tightened, its almost a right angle
Old Nov 25, 2002 | 02:42 PM
MaxRPM's Avatar
You said you opened the bleeder vlave, did you close it? You probably have air in the lines now. You will have to bleed them whcih you will need a buddy to help you.
Anyhow try pumping the brakes a few times. Your brakes should still be there. Turn on the car and pump somemore. Drive the car slowly and make the brakes are working well before driving at normal speeds on public roads. Don't use the brake too hard for the next 200 miles or so.
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
Johnny9595
Sep 16, 2015 07:20 PM
bbsitum
Sep 11, 2015 04:55 PM
A32goldylocks
Sep 2, 2015 06:39 AM
