does the budget y-Pipe come with all gaskets and seals
Old Nov 26, 2002 | 10:31 AM
Gnstrolv's Avatar
I am going to install mine Thursday and I don't want surprises.
J-Rod
Old Nov 26, 2002 | 11:32 AM
acMAX's Avatar
Re: does the budget y-Pipe come with all gaskets and seals
J-Rod
good question...I should be ordering mine soon.
Old Nov 26, 2002 | 12:26 PM
2K2DEMAX's Avatar
Pele ain't got nothing on me
J-Rod
You will need 3 in all.
My budget pipe came with 2 crush ring seal/gaskets (for the front and rear banks). However, it didn't come with the gasket for the main cat. You may be able to reuse the main cat gasket (depending on its condition) but it is always good to use a new one. If you didn't get the 2 crush ring gaskets then you MUST get new ones. Those cannot be reused (will cause leaking).
If you haven't removed the bubble wrapping yet then do that and check to see what you have. In any event, the 3 gaskets can be obtained from any Nissan parts dealer for less than $20 total.
Old Nov 26, 2002 | 12:36 PM
acMAX's Avatar
Re: Re: does the budget y-Pipe come with all gaskets and seals
Originally posted by 2K2DEMAX
thanks for the info!
how do YOU like your budget y btw?
Old Nov 26, 2002 | 12:49 PM
2K2DEMAX's Avatar
Re: Re: Re: does the budget y-Pipe come with all gaskets and seals
So far so good. The power increase is definitely there. To be honest though, there is a little hiss (only when you get on it and is caused by the fact that the flex is not lined inside) but for $160 shipped, I'll take it any day of the week.
Old Nov 26, 2002 | 12:54 PM
Gnstrolv's Avatar
Thanks for Replying. On your hiss commnent, Do you think that is going to lead to the flex problem that some cattman y-pipes where having? The flex would cave in and block the exhaust from flowing. I hope not.
Old Nov 26, 2002 | 01:01 PM
2K2DEMAX's Avatar
Re: Thanks
No, I don't think so. My old cattman pipe had the collapsing flex problem (see my homepage) and that flex was lined inside as well as outside. The new flexes that I've seen, including my budget pipe, is not lined inside but has a "coiled" look (like a set of concentric cirles, as ICEY2K1 put it) and is made of steel. So I'm pretty confident that it won't collapse. When you get the bubble wrap off (that's a task in itself - they wrap that sucker tight!! )look at the inside of the flex and you'll see what I mean.
Old Nov 26, 2002 | 01:04 PM
Gnstrolv's Avatar
That makes me feel much better, thank you again.
Quickywd01
Sep 21, 2016 09:36 PM
mpbclutch33
Dec 26, 2015 11:11 AM
knight_yyz
Nov 1, 2015 01:34 PM
