Headlight Problem on a 2K - Help and Ideas Please
Old Nov 28, 2002 | 03:12 PM
BlkStnValyMaxima's Avatar
I just replaced the headlight harness on a friends 2k Maxima because they were all melted from Nokya bulbs. After wiring the new harness up and turning the lights on the low beams work but when I try to turn on the High Beams the light goes dim. Any ideas?
Old Nov 28, 2002 | 05:00 PM
BigDogJonx's Avatar
Remember on the H4 harnesses there are 3 wires. Two are switched grounds and the other is the shared 12V.
As long as you wired it correctly you should not have a problem. All I can say is that use a volt meter and make sure you wired it correctly cause it seems like you have not wired it correctly.
Dixit
Old Nov 28, 2002 | 11:22 PM
RBa's Avatar
RBa
Re: Headlight Problem on a 2K - Help and Ideas Please
I had the same problem a while back.
All I can say is, keep on trying til you get the right wires..
Old Nov 29, 2002 | 01:14 AM
ThurzNite's Avatar
why wire harness did you use? i did a search about a month ago for "harness" and discovered that cheapy harnesses suck. Maybe u got one of the inferior ones? btw, my Mtec 80/100 9004 bulbs haven't fried the stock harness yet. The Noks aren't even overwatted like the Mtecs are...dunno why your harness melted?
Jae
matts95max
Apr 23, 2025 10:44 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
