Question about the base Stereo (single/CD) in the SE 2k2/3
Old Dec 2, 2002 | 10:51 PM
PeterUbers's Avatar
Is the base 6-spk system BOSE? The one that has the singleCD player? Or is a generic "AC/Delco"-eque brand?
Old Dec 3, 2002 | 12:00 AM
DARKMETH's Avatar
Depends...
The Bose sound system (Speakers Only) uses a deck manufactured by Clarion... If I had to guess, the single would be the same, the only difference would be no Bose speakers... Any know otherwise?
Old Dec 3, 2002 | 05:17 AM
2K2SE's Avatar
It's a Clarion, but I'm not sure if it's the same as the HU used for the Bose system. According to MiniRX7 in this post the Bose speakers use a much lower impedence than the norm, so that implies a different HU.
Old Dec 3, 2002 | 10:49 AM
dwapenyi's Avatar
The difference is the setup going to the speaker. In the BOSE setup, the HU feeds a signal to the AMPS which then go to the 1 ohm speakers. In the non-bose, or traditional setup, the HU is also the amp, so the powered signal goes straight to the higher ohmed speakers.
If your system was BOSE, you would know it. There would be some BOSE label on the HU and the rear speakers or sub-woofer.
DW
9aj9
Apr 5, 2020 12:11 AM
ColdCananda
Sep 20, 2015 10:45 PM
pears
Sep 18, 2015 05:25 AM
EdRomo86
Sep 12, 2015 07:49 PM
Violator
Sep 9, 2015 10:14 AM
