Would a busted 2K VIAS throw a code?
Old Dec 4, 2002 | 08:36 AM
asu174's Avatar
Clay Aiken has fancy genitals
Anyone know if Auto Zone will be able to detect if my VIAS is busted? My SES light won't light up, will it?
Old Dec 4, 2002 | 08:39 AM
UMD_MaxSE's Avatar
Got Bent?
I think the only thing that will throw a code having to do with the intake manifold is the swirl control system (cali spec only).
Old Dec 4, 2002 | 12:41 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i remember reading all the threads started by maxgator about his busted VIAS and i dont remember him saying it threw a light. his was busted and fixed by nissan. i thought for a while mine was having the same troubles, so i dissconneted my VIAS and ran the car. it was definately slower up top. all though after i disconnected and reconnected it, i could hear it switch over much better. maybe i was just listening harder but there was a difference. i wanted to run a similiarly equipped maxima but there is not one close enough to test.
Old Dec 4, 2002 | 12:42 PM
asu174's Avatar
Any idea where to disconnect it?
Old Dec 4, 2002 | 12:44 PM
UMD_MaxSE's Avatar
Got Bent?
On the passenger side of the engine in the front, there is a box with two vacuum lines going into it... Underneath is the connector...
Old Dec 4, 2002 | 12:55 PM
Larrio's Avatar
The Definitive AE Master
asu, if you ever head down to cali... we can run to see if yours is broken
Old Dec 4, 2002 | 01:09 PM
asu174's Avatar
In the front? Like where? Show me in the pic.??
Old Dec 4, 2002 | 01:14 PM
Jeff92se's Avatar
I'm needing a caw
Well if you don't know how your varible intake system works, it's gonna be hard to check it(especially when you don't know where the mechanism is). I don't think it will throw a code because it's not really directly related to the emmissions.
You should really invest in a manual.
Old Dec 4, 2002 | 01:16 PM
asu174's Avatar
I have one. I'm ADHD and I hate reading. Damn. Guess I need to pick it up tonight from 2k2_6spd's house.
Old Dec 4, 2002 | 01:21 PM
Jeff92se's Avatar
I'm needing a caw
ADHD?
Old Dec 4, 2002 | 01:23 PM
sloppymax's Avatar
attention deficit hyper disorder
i dont know how quick he would be to respond but pm maxgator, he took the time to walk me through the messages. i also plugged it up with a rubber cap to keep anything from going in.
Old Dec 4, 2002 | 01:39 PM
asu174's Avatar
Found it....
http://forums.maxima.org/showthread....ve+vias+thread
Old Dec 4, 2002 | 02:32 PM
sloppymax's Avatar
Found it....
before you try to run it disconnected, have you ever had any trouble actually hearing it switch over at 5k? the 2k2's, at least blubyu2k2's has a different tone when his switches over. mine is more high pitched while his is more a grunt. its difficult to hear over the intake but i was curious if you hear yours switch over?
MAX2000JP's Avatar
Broken VIM doesnt throw a code.
To test it look under the box type object on the right side of the intake manifold. Have a friend rev the car to WOT and see if the lever actuates.
Old Dec 4, 2002 | 02:42 PM
Jeff92se's Avatar
I'm needing a caw
ACtually, you can just push the throttle bar by hand inside the engine bay. Should pop open at about 3000-5000 rpm
Old Dec 4, 2002 | 02:43 PM
MAX2000JP's Avatar
That you can, but its hard to do look for the VIM actuator and rev the engine.......if you have never done it before.
It actually should open around 5000-5400 rpms IIRC.
Old Dec 4, 2002 | 03:26 PM
Max_Gator's Avatar
Check the damn thing already asu - how long has it been now?
Vias won't throw a code. And . . . according to Nissan that means there must not be anything wrong.
Of course, I had to PROVE to them that the vias could be turned off.
Old Dec 4, 2002 | 03:35 PM
Jeff92se's Avatar
I'm needing a caw
Well on my VE 3-gen it's really easy. I think the 2k2's set up is relatively the same(actuator location and throttle pulley location). Just rev the throttle and look left.
Old Dec 4, 2002 | 05:42 PM
sloppymax's Avatar
im sure im not the first and im sure i wont be the last but when i had my VIAS disconnected, i was wondering it was possible to change the point at which it switches. i would assume its sets at an optimal point but thats is with a stock car. with certain bolts on that allow more air in and more air out, could adjusting the switchover provide any benefit and is it even feasible or possible?
Old Dec 4, 2002 | 08:05 PM
DAVEB's Avatar
I can back this up- Just went out to my car in a 35F howling north wind (we dumb Texans do not handle cold weather!)- If you look at the bottom of the VIAS, there is a little rod that pulls on a pivot to open the VIAS flap inside the intake- when you rev the engine the thing pops open right at 5K rpm's! I guess mine is working!
Old Dec 5, 2002 | 05:54 AM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
You really would think that a busted VIAS would throw a code, because without it, it significantly reduces the engine's power. Honda's throw a code when a VTEC solenoid is malfunctioning, but this is a very very rare occurance when it happens.
Hmm...on the otherhand, when the Acura CL-S came out, they apparently had some problems with busted actuators also, and they didn't get a code for that...
Old Dec 5, 2002 | 07:02 AM
Max_Gator's Avatar
As far as I know, no one on the board has reported a problem with the solenoid. I suppose that if that happened a code might be thrown.
But the problem with the VIAS has typically been that the solenoid/vacuum etc all work, and the VIAS APPEARS to work if you watch the actuator flip BUT there is a mechanical failure in the enclosed intake manifold that prevents the butterflys from opening (or closing) as the case may be.
Trust me, Nissan wouldn't even believe my dyno that showed 40hp to the wheels loss because there was no code.
Old Dec 5, 2002 | 07:05 AM
asu174's Avatar
Mine is broken. See other thread.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
King_Ten_Ahead
Sep 27, 2015 02:24 PM
dshinn
Sep 26, 2015 08:07 PM
