Daytime Running Lights Installation
Old Dec 5, 2002 | 05:23 PM
wpr's Avatar
wpr
I just got a kit to add daytime running lights to my 2001 SE and was wondering if anyone here had done this, and if they had any suggestions.
Two questions after reading the instructions:
(1) are the Maxima headlights 3-wire or 2-wire,
(2) is the switching positive, negative, or double-negative?
Thanks for any help.
Old Dec 5, 2002 | 06:48 PM
gxe2se's Avatar
city lights...?
If you're talking about city lights...i just spliced them into my parking lights.
and the max is 3 wirea... one ground... one low beam... one high beam...
good luck
Old Dec 6, 2002 | 05:41 PM
ThurzNite's Avatar
i'm interested...what kit did you use? what wattage do the DRL run on?
Jae
Old Dec 7, 2002 | 06:11 AM
wpr's Avatar
wpr
The kit I got is from Rally Manufacturing, number 3239. Not too complicated, just connect four wires. I just want to make sure I'm using the correct four wires, that's why I asked for help.
I don't think it dims the lights, so they will be running at full brightness, which is fine with me.
Of course, it would be nice if Nissan had equipped the Maxima with DRL.
Old Dec 7, 2002 | 07:15 AM
Richard Scott's Avatar
Are the rest of the lights (tail, sidemarkers, and license plate) on when the DRL's are activated or do you have to manually turn these on when it gets dark??
Old Dec 7, 2002 | 07:19 AM
wpr's Avatar
wpr
Only the headlights come on with DRL. I currently turn the lights on when driving, but the DRL option is more convenient and my insurance company offers a discount if the car has it.
Old Dec 7, 2002 | 11:18 AM
TimW's Avatar
The silent but deadly Moderator
proper DRLs as run with the factory options would be highbeams run at half voltage...
if youre running full voltage low beams, why not just leave the lights on? I mean, the SECU will turn the lights on and off with ignition.
I just left my lights on all the time before I got the 2k2 HIDs. I would leave the HIDs on too, but I think the voltage drop on cranking would kill the burners/ballasts pretty quickly.
One thing to remember that if they are a true DRL (6v on highbeams) that it will shorten your bulb life. Electricity 101: lowing voltage while maintaining resistance will raise the amperage. Even in the manual it states DRLs burn out quickly compared to your other bulbs. I think its totally worth it tho. You only have to prevent one moron from not seeing you and crunking up your car to make it worth it.
Old Dec 7, 2002 | 11:49 AM
PCGuRu2K's Avatar
Re: Daytime Running Lights Installation
I have the H4 and Tuensignal wiring diagram on my site.. That should help you through...
http://pcguru2k.cjb.net/images/h4wiring.jpg
Old Dec 7, 2002 | 04:56 PM
wpr's Avatar
wpr
Re: Re: Daytime Running Lights Installation
Thanks for the pic, but the wire colors don't match my car. There are three wires to each headlight bulb: green, blue, and orange. Which wire should the kit be attached to?
The kit has four wires:
* black - to ground
* red - to the plus battery terminal
* blue - to fuse at fuse panel controlled by ignition (a/c, radio, wipers)
* green - to low beam wire
Questions:
* Which wire should the kit's green wire be attached to (green, blue, or orange)?
* Can I just put the kit's blue wire in the fuse box secured by one of the fuses?
* If the blue wire is connected to a power source, why is there a red wire attached to the battery?
Thanks for any help with this.
MaximaDrvr
Aug 19, 2015 08:20 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
kirkhilles
Aug 8, 2015 10:53 AM
MikesChevelle
Aug 6, 2015 11:36 AM
