Electrical Help Needed
Old Dec 8, 2002 | 01:05 PM
wpr's Avatar
wpr
I'm attempting to install a daytime running lights kit.
The kit has four wires:
* black - to ground
* red - to the plus battery terminal
* blue - to fuse at fuse panel controlled by ignition (a/c, radio, wipers)
* green - to low beam wire
There are three wires to each headlight bulb: green, blue, and orange.
Questions:
* Which wire should the kit's green wire be attached to (green, blue, or orange)?
* Can I just put the kit's blue wire in the fuse box secured by one of the fuses?
* If the blue wire is connected to a power source, why is there a red wire attached to the battery?
Thanks for any help with this.
Old Dec 8, 2002 | 08:49 PM
PCGuRu2K's Avatar
Re: Electrical Help Needed
* black - to ground
Questions:
Here's the 5thgen headlight, turn signal wiring diagram.. You can use this as reference. It's on my site..
http://pcguru2k.cjb.net/images/h4wiring.jpg
CorollaULEV
30
Aug 9, 2021 08:11 PM
smplyamzng
Dec 13, 2015 01:19 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
TonyJr
Aug 20, 2015 12:14 AM
Samedi
Aug 13, 2015 04:05 PM
