Service Engine light
Old Dec 10, 2002 | 02:28 PM
Briansmax's Avatar
I just replaced my exhaust with a custom one and put in the Stillen intake and now my service engine soon light is on. Anyone have this happen and have a easy solution? Thanks
Old Dec 10, 2002 | 02:31 PM
chinaonnitrous1's Avatar
Re: Service Engine light
Please post the year of your car..=) and when you say exhaust...just the muffler? or Cat back? Headers? Ypipe?. And im assuming you put the stillen pop charger intake? How does your car feel? Normal? Loss of power? Could be as simple as closing your gas cap more-!
Old Dec 10, 2002 | 02:37 PM
Briansmax's Avatar
Re: Re: Service Engine light
Its a 2000 and its a cat back exhaust.the 02 sensor is still in the little piece after the cat too. no y-pipe or headers and it is the stillen pop charger. car feels normal and a gain of power.
Old Dec 10, 2002 | 03:03 PM
BigDogJonx's Avatar
Re: Re: Re: Service Engine light
Okay lets do this, clear the Check Engine light by removing the negative cable overnight. And see if it comes back. Might just have had a slight initial issue with the Stillen Intake.
Old Dec 10, 2002 | 03:13 PM
Briansmax's Avatar
Re: Re: Re: Re: Service Engine light
thanks- ill try that
Old Dec 10, 2002 | 04:10 PM
hubbabubba's Avatar
Re: Re: Re: Re: Re: Service Engine light
Hi,
I have the SES light (dim right?). As someone posted, it may not be a good idea to take off the cable from your battery if you still can have warranty work done on it. If you are able to take the light away simply by disconnecting from the battery, it may mask a problem that really exists. Then again, you have mods that will more than likely void your warranty.
Old Dec 10, 2002 | 05:51 PM
Did you have the car ON but engine off? while installing your Stillen pop charger?, did you disconnect the wiring harness thats attached to your Intake?
Old Dec 10, 2002 | 07:26 PM
Briansmax's Avatar
i did unhook the mass air flow sensor connector when i installed the intake and i did not have the car on while installing it.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
Flores94
Aug 11, 2015 12:53 PM
bassmann
Aug 3, 2015 07:53 PM
