Need help???.....Rim question.......
Old Dec 16, 2002 | 09:49 PM
clipse's Avatar
I might be planning on buying a set of Volk Racing GTN Rims.
Here are the specs:
18x7.5
37mm offset
215/40/18 tires
My question is. Will this rim size be a problem for daily driving? Also using a rim with a 37mm offset safe/any good? Anyone who can help a fellow member out your replies will be greatly appreciated. Thanx in advance.
-clipse
Old Dec 16, 2002 | 09:51 PM
MAXRAY's Avatar
Re: Need help???.....Rim question.......
Here are the specs:
18x7.5
37mm offset
215/40/18 tires
-clipse
it should work, but 215's will look like bicyle tires. go w/ at least 235's if not 245's.
Old Dec 16, 2002 | 09:58 PM
20th maxstyle's Avatar
245's are great. I have 245/45/17 on my stock rims they will be great on your 7.5's. Go for Dunlop SP5000 or Bridgestone S03 Pole Position's. Falcon ZIEX suck.
Old Dec 16, 2002 | 10:09 PM
clipse's Avatar
MAXRAY & 20th maxstyle: Thanx for your replies.
Yes i was planning on swapping out the tires for either 235's or 245's. Beside the size of the rim and tires. Will running a aftermarket wheel that has an offset of 37mm be a problem? Rims experts i need your help?....
Old Dec 16, 2002 | 10:21 PM
clipse's Avatar
anyone?....
Old Dec 17, 2002 | 04:57 AM
mpc578's Avatar
235/40/18 is out of spec for a 7.5" wide rim. I would check the FAQ about rim/tire sizes before you make that decision...
Old Dec 17, 2002 | 05:03 AM
T-bone's Avatar
Here are the specs:
18x7.5
37mm offset
215/40/18 tires
-clipse
The ride on the tires you have selected may be rough and the likelyhood that you will bend a wheel is high. Try stepping up to 225 or 235.
Old Dec 17, 2002 | 08:20 AM
clipse's Avatar
mpc578 & T-bone: Thanx for your info about the tires.
My question is,will it be safe to run an aftermarket wheel that has an offset of 37mm?
Old Dec 17, 2002 | 09:48 PM
clipse's Avatar
Anyone?????......
Old Dec 17, 2002 | 10:00 PM
freeze2k2's Avatar
Anyone?????......
37 offset is fine. Ive got 8 inch wide wheels with a 40 offset. With a 7.5 wide you could easily go with a 35 offset.
Old Dec 17, 2002 | 10:13 PM
clipse's Avatar
Thanx for the helpful info freeze2k2
