MAF Sensor and Pinging/Knocking?
Old Dec 22, 2002 | 11:55 AM
MaineI30's Avatar
Guys,
I did a lot of MAF sensor searching and reading the threads and can't find an answer to my specific question.
My car was hesitating and shifting weird and in serious low-power mode and I brought it into the dealer. I was also seeing some knocking/pinging under light load (2500 rpm or so) up hills. About a year ago I had my coils replaced under warranty (there's a TSB for it somewhere..)
Of course we went through the bullsh!t where it might be the mods' fault, etc. Then finally they swapped my MAF sensor with one from another car and my car ran great while the other ran crappy. So they are going to replace my MAF sensor under warranty.
From reading the other threads, I know the Stillen POP-Intakes (and various other aftermarket intakes and filters) have been blamed for dead MAF sensors.
So it seems like a new MAF will solve the low power issue. However, will it stop the knocking or am I dealing with coil issues again?
Thanks for your input.
Old Dec 23, 2002 | 10:47 AM
MaineI30's Avatar
Ha!
Thanks for nuthin, guys!
Anyway I am probably going to pick it up today -- will let you all know how it is.
Old Dec 23, 2002 | 10:51 AM
Virus's Avatar
I know this sounds funny, but I was getting knocking and pinging with just my Berk Intake. When I put the FrankenCar midpipe on, the knocking and pinging went away.
Old Dec 24, 2002 | 03:01 AM
adman's Avatar
Re: MAF Sensor and Pinging/Knocking?
Oily filters are usually the problem with the MAF.
Clean it and it will work fine again. Mine did!
ADMAN
Old Dec 24, 2002 | 07:44 PM
MaineI30's Avatar
Re: Re: MAF Sensor and Pinging/Knocking?
ADMAN
Right, but do the failures thereof ever result in pinging and knocking? No one seems to be able to answer that...
Old Dec 24, 2002 | 08:25 PM
adman's Avatar
Re: Re: Re: MAF Sensor and Pinging/Knocking?
Sometimes. My car used to stall at stop lights because the MAF was whacked. It can also cause the ECU to change the air/fuel mixture and/or play with the timing because it cannot determine what the problem is.
Have you checked the flex section of your exhaust as well???
ADMAN
Old Dec 25, 2002 | 10:49 AM
mjg's Avatar
mjg
ADMAN
this is some dumb question...
why do you oil the filter, and how often do you do it?
Old Dec 26, 2002 | 11:17 AM
[maxi-overdose]'s Avatar
Guys,
I blame the quality of Nissan MAF or over-oild K&N filter. Not all MAxima with blown MAF have after market intake. Nissan issued a TSB on replacing MAF.
here is some info on knocking/pinging, credit : Daniel B. Martin.
Originally posted by Daniel B. Martin
Pinging, also called engine knock, has a sound often described as an unpleasant irregular metallic rattle, similar to shaking a coffee can full of marbles. Pinging is pronounced when the engine is under load, such as climbing a hill or rapid acceleration.
Causes of pinging include:
- fuel AKI too low
- ignition timing too far advanced
- lean mixture
- carbon deposits in combustion chambers
- EGR valve stuck closed
- EGR passages obstructed with soot
- EGR vacuum signal hose(s) split, broken, or disconnected
- engine running too hot
There are other vehicle sounds which are similar to pinging. The most common example is an exhaust system heat shield which has become loose and rattles or buzzes, especially at certain engine RPMs.
Your Maxima has a Knock Sensor which detects pinging and signals the Engine Control Module (the computer). The ECM responds by retarding the ignition timing to eliminate the pinging. For this reason... IF your Knock Sensor is working... you have never heard your Maxima engine pinging.
and a bad MAF can lead you to one of the possibilities above.
Old Dec 26, 2002 | 01:45 PM
maximadave's Avatar
detailerdaveb@gmail.com
I still have pinging issues myself and I even replaced my coil packs. The dealership tells me its the dense air in the Injen CAI that causes the pinging under a light load.
What should I do? Maybe I should ask them about my MAF sensor too, mine has never been replaced...
Old Dec 26, 2002 | 01:51 PM
Jeff92se's Avatar
I'm needing a caw
Oh my, you dealership has a bonehead for a service manager. Ask him, what if the air outside is 32 deg F? Is that air gonna be any less dense than the air from the cai in 40deg F weather?? geez.
I would request that they switch and see if it makes your car run better. Do you have any other maxima buddies around you that you could swap mafs with? Or try CAREFULLY cleaning it as some others have done(at your own risk)
Old Dec 26, 2002 | 02:00 PM
maximadave's Avatar
I would request that they switch and see if it makes your car run better. Do you have any other maxima buddies around you that you could swap mafs with? Or try CAREFULLY cleaning it as some others have done(at your own risk) [/B]
Thanks Jeff
I'll go down to the dealership tomorrow...
Old Dec 26, 2002 | 03:27 PM
Airgar's Avatar
I have had many of the same issues with my 2000se as I am reading here. Car ran like crap, took off the Stillen hi-flow and went back to the stock box with K&N insert and it ran much better but still not great for a coupla months. I just replaced my MAF and had my ECM reprogrammed and now, the car runs great. The real good news is that the MAF sensors are now incredibly inexpensive (CDN$84.99)which I believe translates into about a buck ninety for you American folk. I even put my Stillen Hi-flow back on and with my y-pipe, I have all my wahoo points back. Do this and you should be fine.
Old Dec 26, 2002 | 05:22 PM
MaineI30's Avatar
Very good to hear!!
CAN$85 canadian is about US$50.
Also -- I heard they cost something like US$400, but that included the housing as well. My service manager told me today that the part he had ordered was actually superceded by a newer MAF sensor, not sure which one that is. Just glad it's covered under my warranty.
Old Dec 31, 2002 | 10:38 AM
MaineI30's Avatar
got the car back
Well guys,
I got the car back last night. Took it for a decent drive around town and on the highway. It's running great. They replaced (under warranty) my MAF with a new "superceded" MAF sensor part #22680-2Y001.
Although the primary code from the SES light/ECU was P0171 (fuel system lean bank 1), they also said that one of the engine codes that was in the history was P0140, which I'm going to be doing some searches on here. They said it was "heated oxygen sensor #2, bank #1." They said they cannot deal with that particular issue because of my Cattman y-pipe and the relocation of the sensor. The tech said that the slight relocation resulted in putting the O2 sensor "in line with bank #2 not bank #1" .. they said, of course, they'd be happy to fix it if I put my stock pipe back on...
Anyway the car is, at the moment with its new MAF sensor, running superb. Just wanted to let you guys know, especially those of you with similar issues.
Stay
Old Dec 31, 2002 | 11:28 AM
Dave Lopez's Avatar
Re: got the car back
Well guys,
Stay
Ive had similar issues with my 2000 Max. Im taking my car back to the dealer on Thursday to hopefully resolve this issue. Im going to insist that the problem is a bad MAF.
Old Dec 31, 2002 | 11:32 AM
2k2nyc's Avatar
Is the knocking and pinging sound you guys are reffering to like an old piece of sh@t car sound, under light acceleration. B/c I have an injen and my car makes that sound sometimes as well. If so, does a new MAF solve this problem, b/c my dealership had no idea what was causing it?
Old Dec 31, 2002 | 11:50 AM
maximadave's Avatar
I'm curious too since my car is at the dealer right now being fixed (hopefully) for the pinging, replacing the Blose deck, and dash rattles
Old Dec 31, 2002 | 12:11 PM
djPlayboy's Avatar
My car also has the pinging sound, but i am not using the K&N that cam with my berk intake im using a APC dry filter(For Now). Also I only notice the pinging when its about time to do any oil change Nissan told me to use a higher grade of gas(hmm is there any thing higher than 93 octain other than racing fuel....idiots) plus i use valvoline 5w30 syn oil
edit: the pinging was worse when i had the K&N probly because i think i over oiled it, went to the dry cone filter it went away, also the sound is usualy first thing in the morn... My mecanic that i trust says its probly the lifters not getting enought oil when the car is first started.
Old Dec 31, 2002 | 12:33 PM
sascuderi's Avatar
Hey Maine I30, how many miles on your I30?? I am trying to figure when these MAFs tend to go.
Old Dec 31, 2002 | 12:54 PM
maximadave's Avatar
just got off the phone with Mossy Nissan and their top tech told me that light pinging is normal and help on the gas mileage and if I wanted to take this any further I should contact consumer affairs. WTF?! Never again will I buy another Nissan because of my service experience.
Old Dec 31, 2002 | 01:01 PM
TimW's Avatar
The silent but deadly Moderator
maximadave, arent you out in Cali with all that oxigenated gas? Up in the NE, you'd be on oxigenated 'winter' gas right now. You *might* ping regardless.
then again, there is also that ecu harness wire breakage TSB, ugh, I wouldnt want to have to diag that one.
Old Dec 31, 2002 | 01:41 PM
maximadave's Avatar
the dealer told me that a "light" spark knock is normal and not to worry about it. Well, its definately pinging more than it should IMHO...the dealer said they checked everything including sensors and found no problem. On the other hand, they never mentioned my injen cai when I picked it up earlier today...I guess I'll have to live with it
Old Dec 31, 2002 | 02:57 PM
MaineI30's Avatar
52k. Has had the Stillen Pop-Intake since about 15k miles.
Old Dec 31, 2002 | 03:00 PM
MaineI30's Avatar
not trying to be snide, but that's another reason I'm really glad I bought infiniti this time.
Old Dec 31, 2002 | 03:05 PM
MaineI30's Avatar
I personally would not tolerate any knock at all. I'm no mechanic, but it would seem that your engine is messing with the timing to compensate for SOMETHING. Or your knock sensor isn't working, or whatever. A lot of guys on here know WAY more than me, please jump in...
Of course, if you're not getting any ECU error codes (engine light) it'll be a harder row to hoe..
Old Dec 31, 2002 | 03:40 PM
sascuderi's Avatar
knock
My 95 Max and 2000 I30 both have very light knock at times, even with premium.(Only when accelerating up a slight incline) The manual states light knock is "normal". I would guess that since I have noticed it in both of my cars from day one, then it must be normal to notice it at times. However, if it is during constant speed on level ground them I would suspect bad ignition coils from reading the TSB.
ps my sister has my 95 Max and just reached 110,000 miles. Still going strong!
Old Dec 31, 2002 | 04:31 PM
maximadave's Avatar
Re: knock
I had all of my coils replaced and on certain hot days I can cruise say around 40 mph in 3rd gear at a constant speed with a "light" tapping or pinging noise coming from the engine. I've been told that long term pinging from an engine can cause premature engine failure I guess I'll have to live with it....
speaking of buying an Infiniti, is their dealer service better than Nissan? My next car would definately be a G35 coupe or 4 door.
Old Dec 31, 2002 | 09:30 PM
MaineI30's Avatar
Re: Re: knock
I had my coils replaced last year, too.
Having owned two Nissans and an Infiniti, I'd say Infiniti service blows Nissan away. Also the warranty is significantly longer. And you get a loaner car, etc. etc.
I'd say if you ask around the .Org re: difference in service, there are several who'll tell you it's actually worth the money... I've had some disagreements with my service manager re: problems and some mods, but it's always been resolved to my satisfaction and they definitely know how to provide excellent customer service and make sure the customer is happy.
Old Jan 10, 2003 | 11:13 AM
eblum's Avatar
Coils
Does anyone have instructions on how to replace the coils? I searched the website and came up empty!
Thanks,
Eric
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
