HOMELINK SYSTEM
Old Jan 2, 2001 | 03:08 PM
Maximam's Avatar
Has anyone had problems getting there Homelink system to work? Mine won't program.
Mark
Old Jan 2, 2001 | 03:30 PM
2000MaximaSE's Avatar
Mine works fine, i had to reprogram it once but it works fine after that,
Adam
kpark's Avatar
Make sure you keep at least a distance of 2 or so inches between the Homelink unit and the transmitter you're trying to program in. Don't hold it too close.
Old Jan 2, 2001 | 04:10 PM
focker2889's Avatar
is the device that you are trying to control uses a rolling code security? if so, you need to teach the device to accept the HL's rolling code feature. I taught my garage door opener by pressing down & holding a HL button and then press and release a smart button on the opener.
Mark
Old Jan 2, 2001 | 04:53 PM
Loe max's Avatar
Mark
My garage has a "rolling-code" that changes codes everytime you close the garage. Its almost the same technology used on ours keys. Heh, my HomeLink works at a greater distance than the Transmiter that came with the garage motor. Make sure whether or not your garage has a "rolling-code" feature and follow the directions for programming the HomeLink on the card that SHOULD be in your glove compartment. If it still doesn't seem to work, you might be heading towards the dealers in the near future!
Good Luck,
Old Jan 3, 2001 | 09:04 PM
Maximam's Avatar
Rolling Code
Thank you everyone for responding. I got my Homelink to work. I did not realize I had a rolling code on my garage door opener.
Mark
Miket2006
Mar 1, 2021 03:55 AM
MichMaxFan
Sep 30, 2015 09:18 AM
Socalstillen
Sep 26, 2015 12:01 PM
RWCreative
Sep 21, 2015 11:01 AM
