The car doesn't purr like it used to...
Old Dec 24, 2002 | 01:10 PM
lcf's Avatar
lcf
50k miles on my 2000 SE/AT and for the past 10k miles, I've noticed that the engine doesn't sound as smooth and is definitely not as quiet as it used to be [at idle].
Any of you guys notice the same thing about your cars?
Any ideas? Could worn belts be causing the sound?
Old Dec 24, 2002 | 01:29 PM
2k1maxgle's Avatar
Re: The car doesn't purr like it used to...
yeah i guess i sorta noticed that too on my 2001 GLE. i have about 55k miles on my car, just earlier today i noticed there was a squeaky noise coming from somewhere...im hoping its just kuz the car was cold and hasnt been run in 2 days...but yeah i noticed its a little louder even b4 i had my exhaust resonator removed.
Old Dec 24, 2002 | 01:43 PM
Garfield's Avatar
man..i thought i'm the only one had this problem.
but i only have 21k miles but didn't feel the same b4.
i think it causing by the cold temp.
it didn't happen in the summer....
Old Dec 24, 2002 | 01:49 PM
lcf's Avatar
lcf
Hm, my car didn't sound very good during the summer either. The cold weather has made it worse though, I'd have to agree with you there. I really don't know what I should do about it. I think I may put in some fuel additive and "clean the fuel injectors" and do some other stuff to see if there is any effect.
Heh.
*shrug*
Old Dec 24, 2002 | 01:56 PM
Garfield's Avatar
Heh.
*shrug*
I was thinking to bring my car to the dealer today and ask them to test drive. But the car was fine this morning.
well, maybe i'll wait until it start again ....
Old Dec 24, 2002 | 03:08 PM
Tanman's Avatar
Try changing the spark plugs, switching to synthetic engine oil, maybe a tune-up?
Old Dec 24, 2002 | 03:12 PM
KP ROX's Avatar
the other responses to this thread make sense. I think part of it is the car just getting older. Kinda like humans, the body starts to ware down and eventually break. That sucks!
Old Dec 24, 2002 | 03:22 PM
yongjun's Avatar
Re: Re: The car doesn't purr like it used to...
Clean the Throttle Body, Change some plugs, clean those injectors. IT should sound fine.
My front two struts are blown and my car just sounds horrible, and I hate driving the SI everywhere.
Old Dec 24, 2002 | 07:46 PM
mjg's Avatar
mjg
it sounds like a loose belt. maybe it was frozen
Old Dec 24, 2002 | 08:44 PM
rubman's Avatar
Re: Re: Re: The car doesn't purr like it used to...
Replacing the plugs made a distinct improvement in the feel of my car. I cleaned the throttle around 40K, but, since I always us 93 Octane, it was barely dirty. I also use different fuel injector cleaners, not often. I do feel that if all of you with 40K or more do the plugs, you'll freak out in the way that the car feels. My car use to slightly idle at red lights, after plugs no more. Just replace with the same as stock, should set you back $60-70. Please post if you do the plugs.
Old Dec 25, 2002 | 07:28 AM
Y2KMaxGXE-R's Avatar
Re: Re: Re: Re: The car doesn't purr like it used to...
This is not "normal" to replace plugs at 40K, they should not go bad at such low mileage (unless mods make them go bad). Our cars don't need any tune up up to 100K mi. If something is wrong, take it up to the dealer, have them change the plugs under your powertrain wtty. (up to 60K mi)
Old Dec 25, 2002 | 09:05 AM
victor's Avatar
i heard that the plugs may go bad due to the MAF sensor going bad, as mine has. i need to check if my plugs are still clean though, to make sure.;
Old Dec 25, 2002 | 09:49 AM
PIONEER's Avatar
At 50K + miles, its time to get rid of those plugs. Also if you can't afford the plugs, make sure you atleast take the Plugs out and inspect each one of them before your 60K Warrenty runs out. The reason for inspection, The Valve Cover Gromets may leak and Flood the Plug Chamber causing the car to idle roughly. If so the case, put the dirty plugs back in, take the car into the dealer and tell them your valve cover is leaking oil into the plugs. Dealer will take care of this under warrenty.
Take the Vaccume hose off the Brake booster, and shove some Injector cleaner down that Hose. It'll caugh and scream for a few minutes but when its all said and done, the car will feel new again
Old Dec 25, 2002 | 12:48 PM
rubman's Avatar
Re: Re: Re: Re: Re: The car doesn't purr like it used to...
Last car I had manufacturer recomended changing oil every 7500 miles. Not in a lifetime. I mean even when it comes to replacing it with Mobil 1, if u do it urself it's only less that $30. I don't think that if you spend $30k on a car you should go with a 100K tuneup. Just my $.02 The only reason that I suggested to do the plugs is, I felt a a big difference in my car.
Old Dec 25, 2002 | 09:07 PM
TimW's Avatar
The silent but deadly Moderator
actually, the maxima is prone to fuel fouling and it may require spark plugs before 100 or 60K.
Old Jan 22, 2003 | 08:56 AM
jconte's Avatar
I changed my plugs at 49K and noticed a difference immediately. Screw the 100K, for the cost of the plugs and the difference it made, it was worth it.
Old Jan 22, 2003 | 10:39 AM
djPlayboy's Avatar
wait till you guys get up to my milage, at 88k my car wines, but i do need to replace my belts. I replaced my plugs at 65k. at 90k im going to my mechanic and were cleaning my injectors when i do my oil change and changing the tranny fluid, and also checking my compresion.
Old Jan 22, 2003 | 03:31 PM
MaxedOut2g's Avatar
you guys are scaring me...im almost out of my warranty, like 35.3k, but i definately want this car to last like 100-150k miles but you guys are making me kinda think twice about that
holla
Old Jan 22, 2003 | 04:31 PM
djPlayboy's Avatar
your car will prolly go past the 150k mark maxedout2g, as for warrenty i got the 100k and ive only used it once, @ 34k i had to get the ecu reprogrammed
Old Jan 22, 2003 | 05:04 PM
kpark's Avatar
How much does it cost to get the plugs replaced at the dealer? Is this something I could do myself or do I need to get a spark plug gap tool and timing light and stuff?
Old Jan 22, 2003 | 05:12 PM
bk2kmax's Avatar
This especially true, I have over 109k on my 2k and I changed my plugs a little b4 the "Recommended 60K Tuneup" and my plugs were completely fried and I do mean fried. The guys at Nissan wondered how my car was able to run that long with the plugs that way.
Forget all the garbage about 100K Tune-up, change your oil at 3k, unless you're using synthetic (then, I'd still watch that) and get your first spark plug check at least by 40K and definitely change them by 48K.
Just my .02
Old Jan 22, 2003 | 08:23 PM
jconte's Avatar
To answer two posts in one:
1. You will definitely get 150K out of your MAX. These are considered wear items and they go at different times for different drivers. Things to consider are geographic locations like always hot, etc... and driving habits. I got over 40k out of my brakes, maybe because I'm not to hard on them.
2. You can do the plugs yourself, some simple tools and a little elbow grease and you'll be fine. I am by no means mechanically inclined and I did it. The dealer cost was over $200. The plugs cost me about $60 on ebay. But you can find them on many websites for the same price.
On a final note, my car runs fine except for the first start and the squeak until warmed up. I am leaning to the culprit being the belts which I will replace int he next week or so Dealer cost $130. I will post the results....
I have also had my fuel injectors cleaned, plugs changed, trans services and synthetic oil since inception and it runs awesome. I try to do as much PM as possible and it definitely pays off...
I plan to get an easy 150K and still get some money when I get rid of it.
My only regret is buying the first year redesign since I had so many problems (mostly minor)....
Old Jan 22, 2003 | 08:43 PM
lcf's Avatar
lcf
I'm looking forward to hearing if the new belts did the trick.
Lakersallday24
Jun 16, 2019 01:35 AM
scutmud
Aug 28, 2015 05:04 AM
AT978
Aug 15, 2015 06:39 PM
BobMax
Aug 15, 2015 12:35 PM
erniel
Aug 8, 2015 09:32 AM
