tires?
Old Dec 27, 2002 | 04:08 PM
jayc5627's Avatar
tires?
can i put 235/45/17 tires on my stock 17" rims? thanx
Old Dec 27, 2002 | 04:09 PM
Maximam's Avatar
You have got to be kidding!
Old Dec 27, 2002 | 04:44 PM
y2kse's Avatar
Old Dec 27, 2002 | 06:38 PM
BigDogJonx's Avatar
Some people have, if you look on the board you can see many are running this. Also this is a very controvercial topic since the DOT recommends the widest you can go on a 17x7" tire is a 225.
Old Dec 27, 2002 | 06:44 PM
y2kse's Avatar
Sorry, Dixit. A 235mm wide tire will fit properly on a 7.0" wide rim provided the aspect ratio is 50 or higher.
Source: Tire & Rim Association Contour (Rim Width) Charts, Frequently Asked Questions (FAQ-U), Page 5.
Old Dec 27, 2002 | 06:55 PM
BigDogJonx's Avatar
http://www.bigdogjonx.com/tra/Tire%2...on%20chart.pdf
Interesting, this TRA I have shows the 234/45/17 as a minimum 7.5"
Dixit
Old Dec 28, 2002 | 06:45 AM
sighere's Avatar
Sumitomo says you can put their 225 45 17's (HTR ZII) on a 7" inch rim. That's the widest I've seen. So I bought some. They should be in next week. In fact the road test by Tire Rack was done on an IS300 w/17 x7's for this tire.
Old Dec 28, 2002 | 08:10 AM
jjames's Avatar
That's true, for a 45 series tire. A 235/50/17 in in spec for a 7" rim. A 235/45/17 is not.
Dixit
Old Dec 28, 2002 | 08:31 AM
jjames's Avatar
Have them put that in writing.
Old Dec 28, 2002 | 08:45 AM
sighere's Avatar
Check out the Sumitomotire website www.sumitomotire.com as well as tire rack's review of the tire wherein they state that the tire was on a 17x7 rim... it is in writing!
Old Dec 28, 2002 | 10:48 AM
y2kse's Avatar
Gentlemen, gentlemen . . .
Apparently we're having a great deal of difficulty reading specification charts. So let's everybody SLOW DOWN and take it from the top.
Begin by proceeding to the Tire & Rim Association Contour (Rim Width) Charts I referred to in my previous post. I'm not going to post a link. If you guys can't find it, you deserve to believe whatever you want to believe.
Proceed next to the rim width specifications for the 225/45R17 tire. Everybody find it? Good. What are the acceptable rim widths for the 225/45R17 tire? Write them down here:
____________________
Next, take a look at the acceptable rim widths for the 235/45R17 tire. Got it? Write them down here:
Finally, check out the acceptable rim widths for the 235/50R17 tire. Write those down here:
Any further questions?
Old Dec 28, 2002 | 10:52 AM
BigDogJonx's Avatar
Y2KSE I agree with you there, I think we just miscommunicated on the series of the tire. Because technically if you go 235 you should go 45 to compensate and keep the speedo closer to be accurate. 235/50 would make it a bit more off.
That is why I assumed when you said 235, you also meant a 45 series. Plus he orinially asked in the post about a 45 series tire.
Dixit
Old Dec 28, 2002 | 10:58 AM
y2kse's Avatar
Dixit
Your point is well taken, Dixit, particularly given the fact that our speedos tend to run fast anyway. If anything, a tire with a smaller overall diameter would help to correct that problem. But keep this in mind. Decreasing the diameter creates more fender gap, stiffens the ride, and may reduce the tire's load capacity.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
