Question about FSTB??????Just Installed..
Old Jan 3, 2001 | 04:09 PM
DeaZaL's Avatar
Allright.. Got my first Mod out of the way today... Just installed Courtesy's FSTB.. Now I have a question about it.. First of all I had to bend a sensor out the way.. anyone else had that problem?? on the right side... Anyways.. the bar is kinda loose without overtighting it...Looks like it need some washers in there..Should I stick some washers in there??? Or is it supposed to move a lil????
Old Jan 3, 2001 | 04:23 PM
dvyuan
if you got the current Courtesy bar you should not have bend or cut anything! The bar needs to be tight and you can do so by adjusting the nuts on the bar with one side off the strut tower. The only modfication I did was I hammer down a tab on the black washer so the bar can fit over it.
Old Jan 3, 2001 | 04:43 PM
punkdork's Avatar
Apparently the black washer can be removed (Part of the install instructions for the Stillen FSTB). I've got the older courtesy bar that required I hack the airbox mount. Didn't need to bend any sensors at all.
You definately don't want any play in the bar, otherwise it won't be a "brace".
Old Jan 3, 2001 | 05:09 PM
PRINCE NISMO
DeaZal I have a courtesy bar also but i did'nt have to bend any sensor. As for how tight the bar should be I used a torque wrench set a 35lbs.
Old Jan 3, 2001 | 05:51 PM
DeaZaL's Avatar
Hmmm...
Weird... I took the washers out.. maybe thats why it's hitting the sensor???? either way it is hitting something and I will take a picture of it tomorrow with the digital camera at work.......
Old Jan 3, 2001 | 05:58 PM
mdeal's Avatar
De-install everything and remove those big, black washers. You'll have to tilt the one to get it from underneath the bracket on the one side. Then, slide the strut bar mounting plates in there (with the bar attached).
I just installed mine and didn't bang anything.
The big, black washers are replaced by the strut "feet".
You need to torque those three bolts on each side to 35 ft lbs.
Old Jan 3, 2001 | 06:45 PM
DeaZaL's Avatar
hmm
Yeah man the left side you had to tilt it to get it on.. I did that.. installed the feet first at 35lb of torq... But on the right side the bar sits on top of a sensor... i will take a picutre tomorrow...
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
